Beogram 5500 solenoid beyond repair.
This post has 9 Replies | 1 Follower
FeatFirst
Posts 5
FeatFirst Posted: Sun, Jan 5 2014 6:13 PM
The solenoid in my 5500 jammed, unfortunately this has caused the solenoid coil to overheat making the whole solenoid irreparable. Is there a suitable replacement available? I have searched the web to no avail.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Where are you based?
Regards Graham
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 5 2014 6:43 PM
First make sure, that the burned coil is not a result of a short in the electronics.
FeatFirst
Posts 5
I am based in Maidenhead Berkshire.
FeatFirst
Posts 5
I have not checked anything else yet as the solenoid will need to be replaced whatever the problem is, so I thought I would see if a replacement is available before delving any deeper.
Dillen
Posts 13,191
Dillen replied on Sun, Jan 5 2014 9:26 PM
Most parts can be found.
As Graham asked, which of the three or four solenoids in there are we talking about ?
This one :
http://www.quality-dream-audio.co.uk/used-spare-parts/beogram-5500-control-board-1.html Whistle
FeatFirst
Posts 5
FeatFirst replied on Sun, Jan 5 2014 10:49 PM
That is exactly what I need. Hopefully when it arrives it won't take long to get it going again.
Thanks Dean
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Jan 6 2014 2:05 AM
If you don't check the electronics first you may end up with another burned solenoid.
//Bo.
A long list...
Dillen
Posts 13,191
Dillen replied on Mon, Jan 6 2014 7:51 AM
If he replaces the whole assy (as pictured on the QDA homepage), he should be
on the safe side.
joeyboygolf
Posts 4,188
FeatFirst:
I do have a replacement board available. I have sent you an email.
Regards Graham
Page 1 of 1 (10 items) | RSS
