Hi Cleve,
I developed the app for Beoworld.
The app remembers your login details as a convenience, but if you want to log out, just type in some incorrect login details.
There is no way currently to edit a post. For this you have to use the normal website. This app was developed using reverse engineering techniques, and I wasn't figure this feature out.
p.
Beoworld app with direct photo upload and emoticons.
These forum, as well as the French forum are missing in the app as they are not on this page. http://archivedforum2.beoworld.org/forums/default.aspx
Hi Phil,
Thanks for this great app!! A suggestion for a future update: when I read a post in a thread, I have to go back to the thread to select the next post, read it, go back, etc. Adding up and down buttons in a post for jumping directly to the next or previous post would enhance reading posts enormously for me!
Regards,
Bart
Hi Phil
Thank you very much for this update. French forum and more are now easy to access. That's a great job !
Nicolas
BeoVision 12-65 / BeoLab 9 / Beo6 / BeoCom 2 / AppleTV 4
Bart:Adding up and down buttons in a post for jumping directly to the next or previous post would enhance reading posts enormously for me!
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
And please can you finally add the edit possibility to your great app?
Jacques
chartz:And please can you finally add the edit possibility to your great app?
And here we go, the new version of the Beoworld app is available for download here...
would it be possible to integrate Beoworld Forum with the Tapatalk application? As far as I know the forum admins must install some software from Tapatalk but it would be great as the software allows very comfortable forum browsing, answering etc. on iOS, Android and Blackberry devices (don't know if there's a tapatalk version for windows phone).
TWG:would it be possible to integrate Beoworld Forum with the Tapatalk application?
Last time I looked, Tapatalk didn't support the Telligent forum software we are running, so that is a no.
--mika
Dimitris-
Dear Phil,
thanks for this nice update of the Beoworld App, I really enjoy it. I noticed that there is no possibility to access the French forum. It is true that it's not the most active presently, but maybe a direct access through the App would help a little bit. Thanks in advance for the next update.
Beocom 6000 - Playmaker Mk2 - Beolab 17 - Beoremote Essence - H8 - H5 - Beoplay A1 - Beoplay M5
If you do log in, the French Forum should re-appear.
DrDimitris:Phil, thanks for your work! But I cannot see edit button in my posts! On the popup menu, i see Quote, Reply but not Edit. What am I missing here?
Ehmmmmm maybe an answer on this please?
Good evening Phil,
Unfortunately, I can only login from my computer, it does not work on the App (iPhone & iPad) and just announces "login failed"...
DrDimitris:Phil, thanks for your work! But I cannot see edit button in my posts! On the popup menu, i see Quote, Reply but not Edit. What am I missing here? Dimitris-
DrDimitris:Ehmmmmm maybe an answer on this please? Dimitris-
BeoNut since '75
PhilLondon: DrDimitris: Phil, thanks for your work! But I cannot see edit button in my posts! On the popup menu, i see Quote, Reply but not Edit. What am I missing here? Dimitris- if you're having this issue, log out and log in again using upper and lower case letters as your login name appears on the website.
Thanks Phil, that worked. It was a lower/upper issue case on username input
Hi Phil!
Editing works at last, thanks!
However, if there was a picture in the message, it is just erased. I'm not sure anything can be done about that.
Great job nonetheless!
Working on it ;-)
It'll take a few more week, but I think the current version is working fine on iOS7, doesn't it. It's just the look that clashes a bit with the new system.
