Can you connect Beolabs to a LED TV using the Digital Audio Out?
nick_muc
Posts 7
nick_muc Posted: Fri, Jan 17 2014 10:05 PM
The sound from my Panasonic DT50 TV is of course terrible and I was thinking of connecting Beoabs by way of a digital analog convertor to the Digital Audio Out on the TV and using Cinch Cables.
Can anyone tell me if this will work ok?
Thanks in advance
Nick
Millemissen
Flensborg, Denmark
Posts 14,680
Hi nick - welcome to BeoWorld,
you can (using an adapter and a trigger signal), but you will probably experience a (slight) delay in the sound.
nick_muc
Posts 7
nick_muc replied on Fri, Jan 17 2014 10:43 PM
I know about the adapter, just never heard of one with a trigger signal - do you by chance know the manufacturer?
Millemissen
Flensborg, Denmark
Posts 14,680
http://www.av-connection.dk/?PGr=6660
or DIY: http://www.hifi4all.dk/forum/forum_posts.asp?TID=71963
Some BeoLabs do work without the trigger - they trigger on the sound signal.
Also see: SoundsHeavenly (link below).
DoubleU
Posts 562
DoubleU replied on Fri, Jan 17 2014 10:58 PM
I guess the digital audio from your Pana is NOT volume controlled. Using only the convertor will result in extreme loud volumes...
Millemissen
Flensborg, Denmark
Posts 14,680
That's another problem - didn't think of that in the first place.
MM - a lucky B&O tv owner Stick out tongue
w5bno123
London
Posts 578
w5bno123 replied on Fri, Jan 17 2014 11:07 PM
nick_5F00_muc:
Thanks in advance
Nick
Hi Nick
What speakers do you intend to use? The new BeoLab 17's & 18's have an optical and phono input for direct connection from a source such as a TV.
Page 1 of 1 (7 items) | RSS
