Is there a difference between the platters of the Beogram 6500, 7000, 4500 and maybe even others or are they all the same?
Cheers,
Kai
3300 3500 4500 8500 9500 have the same.3000 5005 5500 6500 9000 have the same
//Bo.A long list...
BO: 3300 3500 4500 8500 9500 have the same.3000 5005 5500 6500 9000 have the same
Even if this list is correct, they are all interchangeable. The choice is generally either matt or high polish.
The 7000 is the same as the 6500 variants, either white, matt silver or black.
The white variants have white platters while the black turntables have corresponding matt black platters.
It is difficult to be absolutely sure unless you have owned the turntable from new. They are easy to change if damaged!
Regards Graham
joeyboygolf:Even if this list is correct, they are all interchangeable. Regards Graham
So the 7000 is the same as the 3000 5005 5500 6500 9000?
Just to make sure...
Rgds,
