Platters of Beograms
This post has 4 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Sat, Jan 18 2014 3:01 PM
Is there a difference between the platters of the Beogram 6500, 7000, 4500 and maybe even others or are they all the same?
Cheers,
Kai
BO
Halmstad, Sweden
Posts 728
BO replied on Sat, Jan 18 2014 3:12 PM
3300 3500 4500 8500 9500 have the same.
3000 5005 5500 6500 9000 have the same
//Bo.
A long list...
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
BO:
Even if this list is correct, they are all interchangeable. The choice is generally either  matt or high polish.
The 7000 is the same as the 6500 variants, either white, matt silver or black.
The white variants have white platters while the black turntables have corresponding matt black platters.
It is difficult to be absolutely sure unless you have owned the turntable from new. They are easy to change if damaged!
Regards Graham
BO
Halmstad, Sweden
Posts 728
BO replied on Sat, Jan 18 2014 10:01 PM
joeyboygolf:
Regards Graham
Well, got it from the service manual. Myself I got the 9500, 9000 & 5500 and they are all interchangeable, with no visable difference to me.
//Bo.
A long list...
Manbearpig
Posts 908
So the 7000 is the same as the 3000 5005 5500 6500 9000?
Just to make sure...
Rgds,
Kai
Page 1 of 1 (5 items) | RSS
