Beocenter 7002 Caps?
This post has 0 Replies | 0 Followers
John
Yorkshire England
Posts 104
John Posted: Fri, Apr 20 2012 6:05 PM
All 6 yelow Axial caps on board PC6 measure high ESR though the set is working ok. C17 the one Radial cap measures ok. c18 is a Tantlum.
If I change the caps for tne Infra Red receiver will it need setting up? possily with an oscilloscope?
I would like to leave c19 c20 in the Mic Tape input c18 is a Tantlum, I will not  using Tap or mike input Would a bad c19 c20 effect anyting else in the Beocenter?        c19 , c20 are under the pcb in case of leakage.
The reason for leaving capis the wire loom and plastic clips are brittle after 30+ years of use, and I do not want to make more faults.
Finaly still on PC6 R14 a 4k7 preset slider has been hot and I intend changing it.        Is this common or could there be a fault causing excess current  in R14?
                      Thanks for looking John.
Page 1 of 1 (1 items) | RSS
