All 6 yelow Axial caps on board PC6 measure high ESR though the set is working ok. C17 the one Radial cap measures ok. c18 is a Tantlum.
If I change the caps for tne Infra Red receiver will it need setting up? possily with an oscilloscope?
I would like to leave c19 c20 in the Mic Tape input c18 is a Tantlum, I will not using Tap or mike input Would a bad c19 c20 effect anyting else in the Beocenter? c19 , c20 are under the pcb in case of leakage.
The reason for leaving capis the wire loom and plastic clips are brittle after 30+ years of use, and I do not want to make more faults.
Finaly still on PC6 R14 a 4k7 preset slider has been hot and I intend changing it. Is this common or could there be a fault causing excess current in R14?
Thanks for looking John.
