BeoSound Century fret removal
beojeff
USA
Posts 2,012
beojeff Posted: Sat, Jan 25 2014 4:27 PM
Could someone advise as to how to remove the frets from a BeoSound Century? It looks as if each fret might slide away from the Century toward the outermost sides? Is that correct? Must you pull toward you from the corners first to clear any pegs before sliding toward the sides?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Jan 25 2014 4:41 PM
Correct.
First remove the 2 screws on each outerside. Then slide/tilt the cover.
beojeff
USA
Posts 2,012
beojeff replied on Sat, Jan 25 2014 4:54 PM
That was fast! Thanks, Beobuddy.
Page 1 of 1 (3 items) | RSS
