Could someone advise as to how to remove the frets from a BeoSound Century? It looks as if each fret might slide away from the Century toward the outermost sides? Is that correct? Must you pull toward you from the corners first to clear any pegs before sliding toward the sides?
Correct.
First remove the 2 screws on each outerside. Then slide/tilt the cover.
That was fast! Thanks, Beobuddy.
