Display on 7007 - missing pixels
This post has 3 Replies | 0 Followers
synth
Off piste
Posts 105
synth Posted: Wed, Jan 29 2014 11:58 PM
Hi
Just wondering if its possible to fix the display on a 7007 - some of the pixels/LED bits dont work, so I get partial word s/numbers being displayed.
Thoughts welcome.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jan 30 2014 6:43 AM
Possible? Yes.
Easy? No.
Replacing the LED joints, because that's what it is, requires hot air soldering
under a microscope.
The easiest thing, I believe, would be to find a replacement display (or complete board)
from a donor machine.
synth
Off piste
Posts 105
synth replied on Thu, Jan 30 2014 10:49 AM
Thanks for your helping
one question I have is which model machines could supply a donor display?
Im assuming perhaps that ( for example ) a donor display might be common across several systems?
Any suggestions welcome.....  ;-)
Dillen
Posts 13,191
Dillen replied on Thu, Jan 30 2014 7:10 PM
I don't remember if the whole Beocenter 7000 range uses the same display and I seem to remember that there
are two different layouts but look up the part number(s) in the service manual(s) and compare.
Page 1 of 1 (4 items) | RSS
