Hi
Just wondering if its possible to fix the display on a 7007 - some of the pixels/LED bits dont work, so I get partial word s/numbers being displayed.
Thoughts welcome.
Possible? Yes.Easy? No.
Replacing the LED joints, because that's what it is, requires hot air solderingunder a microscope.
The easiest thing, I believe, would be to find a replacement display (or complete board)from a donor machine.
Thanks for your helping
one question I have is which model machines could supply a donor display?
Im assuming perhaps that ( for example ) a donor display might be common across several systems?
Any suggestions welcome..... ;-)
I don't remember if the whole Beocenter 7000 range uses the same display and I seem to remember that thereare two different layouts but look up the part number(s) in the service manual(s) and compare.
