mauszwerg:Don't know wether it is the same with a BV 11 but on a Beoplay V1 you can find Reporting in the customer service menu. Load the report to a USB stick and unpack the files with a computer. the service counter is in tmp > reporting > flash > calibration data. Ralf
jans:Where can I find the customer service menu on a Beoplay V1?
mauszwerg:Load the report to a USB stick and unpack the files with a computer. the service counter is in tmp > reporting > flash > calibration data. Ralf
i wanted to save the tuner settings to a usb stick.
but it doesn't work.
the report i can save to the stick.
same here. Tuner settings cannot be saved to the Thumb Drive...
