Hi there,
I need some assistance for my newly acquired Beogram 9500 turntable. I found that for 33rpm, it just runs too slow at a speed of 3.3rpm. Anyone got any idea where is the problem and how to fix it ?
million thanks!
I suggest that you replace the drive belt before you do anything else.
BeoWorld member Dillen will be able to help you here.
Regards Graham
Check the bottomside of your Beogram 9500. 2 Holes (33 & 45) visible probably meant for speed adjustment?
Brengen & Ophalen
Leslie: Check the bottomside of your Beogram 9500. 2 Holes (33 & 45) visible probably meant for speed adjustment?
I suggest that you do not make adjustments until you fit a new drive belt!
Thanks all, I am new to this, where and how can I get a belt replacement ? Will it be difficult to replace by myself ?
Cheers
Send an email request for a belt to Beoworld member "Dillen"
He can supply a good quality belt.
It is easy to fit , takes 5 mins maximum.
Thanks Graham, very helpful
