Beogram 9500 running too slow
This post has 6 Replies | 0 Followers
woobenedict
Posts 3
woobenedict Posted: Mon, Feb 3 2014 6:22 AM
Hi there,
I need some assistance for my newly acquired Beogram 9500 turntable. I found that for 33rpm, it just runs too slow at a speed of 3.3rpm. Anyone got any idea where is the problem and how to fix it ?
million thanks!
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
I suggest that you replace the drive belt before you do anything else.
BeoWorld member Dillen will be able to help you here.
Regards Graham
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Feb 3 2014 5:28 PM
Check the bottomside of your Beogram 9500. 2 Holes (33 & 45) visible probably meant for speed adjustment?
Brengen & Ophalen
joeyboygolf
Posts 4,188
Leslie:
I  suggest that you do not make adjustments until you fit a new drive belt!
Regards Graham
woobenedict
Posts 3
Thanks all, I am new to this, where and how can I get a belt replacement ? Will it be difficult to replace by myself ?
Cheers
joeyboygolf
Posts 4,188
Send an email request for a belt to Beoworld member "Dillen"
He can supply a good quality belt.
It is easy to fit , takes 5 mins maximum.
Regards Graham
woobenedict
Posts 3
Thanks Graham, very helpful
Page 1 of 1 (7 items) | RSS
