Its very easy, 4 screws from the rear then the screen swings out from the bottom and lifts off.
It must be a design flaw if dust is able to come into the screen glass area. I have a 27" Apple monitor and it also has glass in front of the LCD and it has no dust at all. It is sealed very good. Why don't B&O do this? For the price it is quite unacceptable to have dust building up inside the TV.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
mibook84:It must be a design flaw if dust is able to come into the screen glass area.
BeoGreg: mibook84: It must be a design flaw if dust is able to come into the screen glass area. It´s in B&O tv's roots to have dust under screen ! MX, Avant, BV 10 now 11. All had dust. A B&O tv without dust under anti-reflections screen is not a B&O tv.
Thats cute but I think B&O should be able to advance their technology also :). I was about to buy a BV11 but is a bit off put by the dust issue, and some other issues as well.
mibook84:I was about to buy a BV11 but is a bit off put by the dust issue, and some other issues as well.
BeoGreg:The bv11 is an extraordinary tv in every aspect : picture, sound, design, materials, motorized stand, one perfect remote for ALL your features including Youtube, Spotify. And more. But yes, with a LED maglight you can see some wee dust under the screen. In one way that´s unforgivable whe all agree with that, in an other way, you can easily live with it and totally forget about it (untill the screen is all dust...).
Both BV10 and BV11 has edgelit Led displays but they both obviously suffer from dust inside the screen space. It is not acceptable and that makes it less extraordinary to me. They could put a rubber gasket around the screen so dust can't enter into it. It is actually quite ridiculous that a TV that expensive has such obvious flaws that so very easily could be dealt with.
Michael:They could put a rubber gasket around the screen so dust can't enter into it.
I suspect there's some technical reason why the gap needs to be ventilated.
--mika
tournedos: Michael:They could put a rubber gasket around the screen so dust can't enter into it. I suspect there's some technical reason why the gap needs to be ventilated.
I don't think so. They should be able to cool it in other ways. They could also laminate the screen to the glass. That is how Apple keep dust and reflections from the screen in both iPhones and MacBook Pro retina. It works very well. There is several ways to do it and B&O has just been to lazy.
Here is some pictures I found online of the BV11 production by the way
BeoGreg: It´s in B&O tv's roots to have dust under screen ! MX, Avant, BV 10 now 11. All had dust. A B&O tv without dust under anti-reflections screen is not a B&O tv.
True, however they did something right with my BV5 and BV9 as there isn't any dust in it.
Too long to list....
bayerische:True, however they did something right with my BV5 and BV9 as there isn't any dust in it.
Im not sure the BV5/9 even has a piece of glass in front of it. They are both plasmas and have glass in their screens directly. So no dust can enter into it. BV11/10 just have a glass cover over the thin LCD screen without any kind of gasket or anything, look at my photos. BV7 probably has a sealed screen since it is separated from the loudspeakers also. I imagine lots of dust getting to the screen because of the speakers and holes around the speaker cover - and from the behind of the TV due to circulation.
Chris Townsend:And the 7 and V1.
