Renovation part 1 finished.A Beocord 1500 reel machine is finished stage one.Cleaned all connectors to PCBs every was black of oxide there.Recapped power supplyOiled motorIdentified lampbulbs ( have no service manual )taken out pinch roller for sending to rebuild.Have to order new power cord ( the odd old 2 pol cord )Cleaning up old mess inside mechanics.Missing parts to this machinescrew to front deck. plexi coverB&O logo on tape head coverGuess these are impossible to get hold of ?Things still to do, when get the new pinch roller backMechanical problems with switch board, have not idientifed yetTorx screw and thread inside speed switch knob destroyed by previous owner, have to find somekind of screwTrim the machine., any one that knows if it is possible to buy test tapes for reel to reel machines anywhere ?
My re-capped M75 are my precious diamonds.
Hi Christian !
Ever finished your machine? Any pictures?
Jacques
I found this site for test tapes, dont know if it is active, for your speed dial drill the hole up one size and cut new threads. If I remember right its a 4 mm screw, Drill with 4.2 mm and cut 5 mm threads and put in a new 5 mm grub screw.
No, I am going to get back to the 1500 later on.I postponed the renovation as I wanted to synchornize pinroller orderings, and then other things came in between , I will update later on.
Thats the site where I ordered test tapes.Expensive stuff, but I could not live without them
