Hi there
i'm interessted in a manual to see the procedure to remove the panel of a beovision 5. i had one but lost it in the deep of my computer.
Thanks for your help
Regards
Ron
Quite a procedure.
Remove the front strip and wooden panel.
Remove the 4 screws at the back (hidden)
Release the cables from the panel from the chassis.
Release the 2 allen keys screws on both sides underneath the panel. These screws lowers the panel.
Don't try to release the cables behind the panel instead of releasing them from the chassis. You will end with broken connectors.h
done! works great! there was a loooooooooooooot of dust inside. now it's clean and replaced.
thanks for your help
regards
ronny
i just didn't know this step.
Good job!
