Manual to remove panel of a Beovision 5
This post has 4 Replies | 2 Followers
tirolervierkantholz
Posts 5
tirolervierkantholz Posted: Fri, Feb 14 2014 2:34 PM
Hi there
i'm interessted in a manual to see the procedure to remove the panel of a beovision 5. i had one but lost it in the deep of my computer.
Thanks for your help
Regards
Ron
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Feb 14 2014 9:35 PM
Quite a procedure.
Remove the front strip and wooden panel.
Remove the 4 screws at the back (hidden)
Release the cables from the panel from the chassis.
Release the 2 allen keys screws on both sides underneath the panel. These screws lowers the panel.
Don't try to release the cables behind the panel instead of releasing them from the chassis. You will end with broken connectors.h
tirolervierkantholz
Posts 5
done! works great! there was a loooooooooooooot of dust inside. now it's clean and replaced.
thanks for your help
regards
ronny
tirolervierkantholz
Posts 5
i just didn't know this step.
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Feb 15 2014 9:46 AM
Good job!
Page 1 of 1 (5 items) | RSS
