Hi
I've bought a BeoCom 6000 which is set to Danish. How do I change the language to English? Unfortunately, I can't translate the Danish phone menu in order to work out where the language setting is.
Cheers
Stuart
I am not sure you can - you'd probably need to have it flashed to French.
Is it a MK2?
Looks like you can change language on a MK2 (black keys) - you definitely can't on a MK1 (white keys)
hx
White key mark 1 version, so no go then. Thanks for the advice. I'll just have to learn Danish!
I do have 3 of them - the basic neccessary texts are quite easy to learn
e.g. GEMT for "stored" etc... Of course it helps to have at least one in the local language.
And the printed text on the phone you can't change not even on a MKII phone anyway
futurist: White key mark 1 version, so no go then. Thanks for the advice. I'll just have to learn Danish!
That should not be that hard at all
Find the French user manual to guide you through it.
