Change language on a BeoCom 6000
futurist
Posts 29
futurist Posted: Sun, Feb 16 2014 2:28 AM
Hi
I've bought a BeoCom 6000 which is set to Danish. How do I change the language to English? Unfortunately, I can't translate the Danish phone menu in order to work out where the language setting is.
Cheers
Stuart
Millemissen
Flensborg, Denmark
Posts 14,680
I am not sure you can - you'd probably need to have it flashed to French.
Griebel
Posts 416
Griebel replied on Sun, Feb 16 2014 9:21 AM
Confirm that you need to flash the BeoCom 6000 in order to change language. Only a dealer can do it.
hemenex
Posts 569
hemenex replied on Sun, Feb 16 2014 10:24 AM
Is it a MK2?
Looks like you can change language on a MK2 (black keys) - you definitely can't on a MK1 (white keys)
   hx
futurist
Posts 29
futurist replied on Tue, Feb 18 2014 12:12 PM
White key mark 1 version, so no go then. Thanks for the advice. I'll just have to learn Danish!
hemenex
Posts 569
hemenex replied on Tue, Feb 18 2014 2:04 PM
I do have 3 of them - the basic neccessary texts are quite easy to learn Wink
e.g. GEMT for "stored" etc... Of course it helps to have at least one in the local language.
And the printed text on the phone you can't change not even on a MKII phone anyway Stick out tongue
  hx
Millemissen
Flensborg, Denmark
Posts 14,680
futurist:
That should not be that hard at all Big Smile
Find the French user manual to guide you through it.
Page 1 of 1 (7 items) | RSS
