Help needed with beocenter 9500.
Dave
kirby cross
Posts 2
Dave Posted: Sun, Feb 16 2014 12:28 PM
Hi to all. Can anybody help me with my beocenter 9500, i replaced the cd decoder and all went well until i turned it on , all lights came on and then it asked me for a code . Dose anybody know the code and why has this happend?  HELP. regards dave
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Feb 16 2014 12:37 PM
Welcome to Beoworld !
I don't remember if the Beocenter 9500 has an anti-theft code but if this is what it asks for, you will have to key in the code.
If you don't have the code you will have to ask B&O and remember to bring the purchase receipt.
Antitheft codes is nothing we can (or will) help you with here as I'm sure, you understand.
BO
Halmstad, Sweden
Posts 728
BO replied on Sun, Feb 16 2014 12:59 PM
The BC 9500 don't have an anti theft code its a code needed after a memory loss. I think it's 1271 but I'm not sure. It can be found on the forum.
//Bo.
A long list...
Dillen
Posts 13,191
Dillen replied on Sun, Feb 16 2014 1:01 PM
Oh yes, I also remember something about a reprogramming of the tuning offset.
It's in the service manual.
BO
Halmstad, Sweden
Posts 728
BO replied on Sun, Feb 16 2014 1:03 PM
This usually happens if you have replaced the S/W or the lithium battery has been replaced or needs replacing.
Fix the battery or RAM and then:
Using a Beolink 1000 press:1271
After 3 seconds, disconnect the 9500 from the mains and then reconnect. - Done!
//Bo.
A long list...
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Feb 16 2014 1:07 PM
It's even in a FAQ Smile
http://www.beoworld.org/faq_view.asp?id=76
I'm sure there are other programmable things as well, but this will usually sort it for as long as you keep the Beocenter plugged into mains. If you unplug it, it will probably ask for the code again until you replace the lithium backup battery in the CPU module.
--mika
Dave
kirby cross
Posts 2
Dave replied on Sun, Feb 16 2014 1:18 PM
That has worked and iam now playing it . thanks for your helpBig Smile Happy again
Jackplug
Posts 40
Jackplug replied on Sat, Mar 21 2015 9:47 AM
I noticed that if you also just leave the unit for a few hours then it appears to go away on it's own???
Page 1 of 1 (8 items) | RSS
