VOLUME CONTROL WHEEL FOR MASTER CONTROL 5500
jimbo7stars
Posts 4
Silver Member
jimbo7stars Posted: Mon, Apr 23 2012 6:11 PM
Hi there i'm looking to buy a replacement volume control wheel for my master control panel. can anyone here help or tell me where i might be able to get one?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Apr 23 2012 9:48 PM
There are some standard issues with that wheel.
Has the wheel physically broken or is it just not working anymore ?
jimbo7stars
Posts 4
Silver Member
Just not working anymore not physically broken the rest of the remote seems fine most of the time. It occasionally says "no contact".
Dillen
Posts 13,191
Dillen replied on Tue, Apr 24 2012 7:54 AM
If the MCP lights up when you rotate the wheel but the volume is not changed, replace the
wheel opto component (I still have a few original parts in the drawer).
Basic electronic skills and tools are needed (soldering etc.)
If the MCP does not light up when you rotate the wheel, clean the contacts of the microswitch at
the back at the wheel.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The optoswitch may be smothered with accumulated dust which only needs clearing out for the system to work OK again.
I have had 2 like this just lately!
Regards Graham
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
