Beovision 8 40 Grill Replacement?
This post has 9 Replies | 0 Followers
XTHX
Posts 22
XTHX Posted: Sun, Feb 16 2014 10:45 PM
Hey guys!
Haven't talked to you all in a while!
I have had a BV-8 40 for a while and it has a huge dent of the grill. Any ideas of how to fix this? I does not look like the grill can be removed. Do any of you experts have expeirnce in replacing the front casing of a beovision 8 40.
I want it to look new again! lol
Thanks in advance!
MartinW
Posts 389
MartinW replied on Sun, Feb 16 2014 11:02 PM
Just pull it off - its magnetic!
XTHX
Posts 22
XTHX replied on Sun, Feb 16 2014 11:27 PM
Hey Martin,
Thanks for the quick help -
I had read that somewhere else originally too, but when went to see how that would work it became evident that it is actually a metal grill that is glued into the entire front housing of the BV8-40.
Maybe there was also a version that had a magnet release?
thanks again for the response
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Mon, Feb 17 2014 9:59 AM
I want to replace mine as well, but it seems to be glued on(?). The service manual is no help, as there are no disassembly instructions therein.
x:________________________
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Feb 17 2014 10:22 AM
I think they did two versions of the 8-40 casing.
If it's glued on - which it always has been in my cases, then it's a casing change. Not cheap.
I have been told on several occasions though that there is a simple magnetic backed fret, so I'm assuming this was a 'Mk2' version.  I may even have actually seen one - and it does kind of ring a bell, but I've seen so much B&O over the years my brains gone foggy.. Geeked
Lee
w5bno123
London
Posts 578
w5bno123 replied on Mon, Feb 17 2014 11:30 AM
I had to look this up as I recalled there being two variants, but according to the 'Tips' section it indicates the front cover on a MKI and MKII are removable! Part number 3444268 to be precise.
The 26 & 32 were definitely glued to the cabinet.
Teletom
Posts 27
Teletom replied on Mon, Feb 17 2014 12:51 PM
I have a mk1 version and just tried to remove the grill. In my TV it's not glued on and can be removed easily from the left or right side.
Regards Johan
XTHX
Posts 22
XTHX replied on Mon, Feb 17 2014 8:05 PM
Some great info here guys. Thanks!
Would any of you have an idea of pricing for the front casing of the bv8-40?
Looks like this might be my only option considering I was unlucky enough to have the glued on variant.
Thanks!!
Rivenflush
Gothenburg
Posts 333
Have not tried this myself but in Watch forums I have read that silicone spray can "loosen up" glue. Could be worth a try.
http://forums.watchuseek.com/f275/replacing-bezel-insert-ocean-one-542483.html
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
w5bno123
London
Posts 578
w5bno123 replied on Mon, Feb 17 2014 10:16 PM
XTHX:
Thanks!!
The front cover is only held on with magnets at each end and can be carefully removed with a plastic peeler.
Due to the discontinuation of the TV expect to pay about £250 for the aluminium front cover.
Page 1 of 1 (10 items) | RSS
