troubles with BEO MASTER 5 HARDDRIVE
sandmankeren
Posts 5
sandmankeren Posted: Fri, Feb 21 2014 5:12 AM
hello,
i have a BEO MASTER 5 which connect with BEO SOUND 5, i've bought those about 4 years a go.
now since 2 weeks a go, it shows message on my BEO SOUND 5 that the hard drive missing,
I have checked on the hard drive and it seems like it got burned somehow, i bought a new hard drive,
so my questions are :
can i flash/install any windows XP versions on the hard drive ?
after installing the windows xp on the hard rive, what softwares do i need to run correctly on beo sound 5 ?
 anything i need to know for changing and flashing/installing software/ operating system for the BEO MASTER 5 ?
anybody can help me ?
thank you in advance
best regards,
Herrick (herrick19@gmail.com)
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Feb 21 2014 7:05 AM
Unfortunatly this will never work.
You need the bm5 flashtool to partition and install software.
Or find the exact drive and change the board if it's burnef.
sandmankeren
Posts 5
Hello,
Thank you for replying.
Where can i get the beo5 flashtools? How to do it ? Or can you kindly show me a link of a website/thread that disscusing the same problem ?
Cos ive tried looking for the exact hardrive at the local store in jakarta, indonesia, and they dont have that kind anymore, and suggested that i buy a whole new beo master 5 instead.
sandmankeren
Posts 5
hello ...
anybody... need help please
sandmankeren
Posts 5
hello ...
northswede
Stockholm - Sweden
Posts 43
Cant your B&O dealer help you with the flash tool or replacing the hard drive?
Did the motherboard survive or do you have to replace it as well?
Page 1 of 1 (6 items) | RSS
