hello,
i have a BEO MASTER 5 which connect with BEO SOUND 5, i've bought those about 4 years a go.
now since 2 weeks a go, it shows message on my BEO SOUND 5 that the hard drive missing,
I have checked on the hard drive and it seems like it got burned somehow, i bought a new hard drive,
so my questions are :
can i flash/install any windows XP versions on the hard drive ?
after installing the windows xp on the hard rive, what softwares do i need to run correctly on beo sound 5 ?
anything i need to know for changing and flashing/installing software/ operating system for the BEO MASTER 5 ?
anybody can help me ?
thank you in advance
best regards,
Herrick (herrick19@gmail.com)
Unfortunatly this will never work.
You need the bm5 flashtool to partition and install software.
Or find the exact drive and change the board if it's burnef.
Hello,
Thank you for replying.
Where can i get the beo5 flashtools? How to do it ? Or can you kindly show me a link of a website/thread that disscusing the same problem ?
Cos ive tried looking for the exact hardrive at the local store in jakarta, indonesia, and they dont have that kind anymore, and suggested that i buy a whole new beo master 5 instead.
hello ...
anybody... need help please
Cant your B&O dealer help you with the flash tool or replacing the hard drive?Did the motherboard survive or do you have to replace it as well?
