Speakers and fun
This post has 11 Replies | 1 Follower
Michael
Sweden
Posts 2,578
Michael Posted: Sun, Feb 23 2014 4:48 PM
Hi friends!
I bought a used set of BL6000 today with a BS2300 and a Beo4. I took the front covers off to see how the speaker membranes looked and realized that the H6 ear cushion is almost the same size. I am thinking about switching to white front covers and to buy the wall mounts and use them with my bedroom V1 perhaps.
I just got the things delivered to my job today. Will be fun to transport them back by train one piece per trip Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Man - you do have two arms, or?
That would be even more fun Big Smile
Michael
Sweden
Posts 2,578
Michael replied on Sun, Feb 23 2014 8:35 PM
Millemissen:
What would be fun! :) I noticed that the BS2300 has a green light that is on even in standby. A quick google told me it might be either mute or a timer setting but I can't see how I can disable the timer that possibly is set. And it is not mute. Do you know?
I also noticed after listening to Adele album ´21´ that the doors would not close properly all times. They get stuck half way there. If I remove one of either glass panels the other one will slide in completely. I manually pulled them back and forth a bit but it did not help. Perhaps I can fix it someway? Cleaning?
Millemissen
Flensborg, Denmark
Posts 14,680
The BS2300 might be a funny ;-)  early version - which had 2-way communication.
You'll need a BeoLink5000 to turn that green light off then.
The 'door problem' of these older BeoSounds is well known disease - but it can be cured.
Having the V1, you'd hardly need the 2300.
"What would be fun!" - seeing you with a BL 6000 under each arm...and the BS2300 in a backpack, of cource!
Michael
Sweden
Posts 2,578
Michael replied on Sun, Feb 23 2014 8:58 PM
Millemissen:
Hhaving the V1, you'd hardly need the 2300.
Ah! Yes it is probably old. The speakers S/N start with 12, 1997 I believe(?). I love the design of the BS2300. I had a Ouverture before and it was nice and this one doesnt have a tape player so it is much smoother in its design. Why do I need a BeoLink 5000 to turn it off? I mean how did it come on? :) It came with a Beo4!
How do I fix the doors? I was planning on selling it. I got the whole package for a bargain it has only been used rarely.
Millemissen
Flensborg, Denmark
Posts 14,680
'Fix the doors?"  Make a request here, if there is anyone who could do it (or guide you) in your area - or contact your local B&O store.
I am sure the 2300 was not always controlled with that Beo4!
Maybe some times in the arly day of its life it was 'told' to take part in a timer programming - and that was never deleted.
It would be the most funny thing of all, would  if it wakes you up every morning at 6 am 😂
Michael
Sweden
Posts 2,578
Michael replied on Sun, Feb 23 2014 9:12 PM
Millemissen:
Yes the doors. I would rather do it myself since I am very technical myself. I´ll make a request as soon as I have taken it home. It is in my office now. I hope it wont start playing at 6 in the morning for all the people there haha :).
I hope I can disable the alarm some way :D
MediaBobNY
Greenwich Village, NYC
Posts 1,106
With the Beosound in standby mode, press the 'Mute' button on the panel (not on the remote).  That should do it.  With regard to the doors, try the following:  Remove the doors (the 2 clips just snap off).  Use a Q-Tip moistened with Wndex (or similar) to thoroughly clean the upper and lower tracks - you'll find them to be filthy.   Then spray some silicone lubricant in there.  Use the thin tube that inserts into the nozzle to minimize overspray (you'll still probably have to clean a little off).    This fixed my sluggish doors.   Good luck.
Millemissen
Flensborg, Denmark
Posts 14,680
@Michael
By the way - this thread might interest you:
http://archivedarchivedforum2.beoworld.org/forums/t/38354.aspx
Millemissen
Flensborg, Denmark
Posts 14,680
MediaBobNY is the man Yes - thumbs up
Michael
Sweden
Posts 2,578
Michael replied on Sun, Feb 23 2014 9:33 PM
MediaBobNY:
Thanks for the good advice! I should have brought it with me on the train today (gah!). But I didn't want to take it with me as my date to the restaurant so it will have to wait a few days! I got the feeling they where sluggish because of dust since they did move a few times perfectly and not just always.
I now have to figure out what to do with it afterwards. I get so sentimental with B&O gear :).
MediaBobNY
Posts 1,106
If my door fix advice doesn't do the trick see this thread and take Leslie's advice.
Page 1 of 1 (12 items) | RSS
