Beocenter 9000 backup battery
This post has 6 Replies | 0 Followers
YannChris
Larmor Plage - France
Posts 232
YannChris Posted: Tue, Feb 25 2014 9:09 PM
Hello,
It seems that the backup battery of my beocenter 9000 is drained.
Each time it is unplugged from mains, even for a few minutes, "CLOCK" appears on the control panel, but the radio and sound settings remain.
The service manual states that only a precise type of battery can be used.... but does not give any detail.
Can someone tell me which type of battery is needed and where I can find it?
Kind regards,
Yann.
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
the_o_master
Posts 856
I am not sure but I think you don't need new battery. I think the "clock" appears when you unplugg the main even for 30sec. But as I said I am not sure. Look to the user manual, I think to remeber finding this information in it....
R,
Theomaster
Vintage Bang & Olufsen
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Feb 25 2014 9:18 PM
I agree, perfectly normal.
YannChris
Posts 232
YannChris replied on Tue, Feb 25 2014 9:22 PM
Thanks...
 But my Beocenter's battery is the original one (1987) and the unit has been unplugged for 18 months after a move.
It may be wise to change it .
Yann.
Dillen
Posts 13,191
Dillen replied on Tue, Feb 25 2014 9:37 PM
If you feel that way.
It's not important how long it wasn't powered. It's not a rechargeable battery.
It's a 3V CR2032 with solder pins for PCB mounting. Make sure to do the job in an
ESD safe environment as always when handling processor boards etc.
Get the polarity right and of course go gently on the heat and DON'T short a lithium cell!
YannChris
Posts 232
YannChris replied on Tue, Feb 25 2014 9:39 PM
Thank you Martin.
Kind regards,
Yann.
BO
Halmstad, Sweden
Posts 728
BO replied on Wed, Feb 26 2014 12:28 AM
Dillen:
If you feel that way. It's not important how long it wasn't powered. It's not a rechargeable battery. It's a 3V CR2032 with solder pins for PCB mounting. Make sure to do the job in an ESD safe environment as always when handling processor boards etc. Get the polarity right and of course go gently on the heat and DON'T short a lithium cell!
I think its a 2430. Probably desnt matter as long as the volage is correct.
//Bo.
A long list...
Page 1 of 1 (7 items) | RSS
