Hello,
It seems that the backup battery of my beocenter 9000 is drained.
Each time it is unplugged from mains, even for a few minutes, "CLOCK" appears on the control panel, but the radio and sound settings remain.
The service manual states that only a precise type of battery can be used.... but does not give any detail.
Can someone tell me which type of battery is needed and where I can find it?
Kind regards,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
I am not sure but I think you don't need new battery. I think the "clock" appears when you unplugg the main even for 30sec. But as I said I am not sure. Look to the user manual, I think to remeber finding this information in it....
R,
Theomaster
Vintage Bang & Olufsen
I agree, perfectly normal.
Thanks...
But my Beocenter's battery is the original one (1987) and the unit has been unplugged for 18 months after a move.
It may be wise to change it .
If you feel that way.It's not important how long it wasn't powered. It's not a rechargeable battery.It's a 3V CR2032 with solder pins for PCB mounting. Make sure to do the job in anESD safe environment as always when handling processor boards etc.Get the polarity right and of course go gently on the heat and DON'T short a lithium cell!
Thank you Martin.
Dillen:If you feel that way. It's not important how long it wasn't powered. It's not a rechargeable battery. It's a 3V CR2032 with solder pins for PCB mounting. Make sure to do the job in an ESD safe environment as always when handling processor boards etc. Get the polarity right and of course go gently on the heat and DON'T short a lithium cell! Martin
//Bo.A long list...
