Yes, I have become another Beogram freak, but not a lucky one since most of my new stuff always comes with hidden issues!!
I have written also to a forum member about this, but was hoping everyone could chime in and describe their thoughs on this.
I have 3 problems that could be belt related. I have made a couple of videos to illustrate these problems very well.
The first one shows the carrier problem: noisy, and VERY slow during fastforwards/fastrewind. I have no clue what's going on. Thought it could be the carrier belt but it does seem to move at the correct speed when "Play" or "Stop" are activated, right?
https://www.youtube.com/watch?v=iuPKHen9wvE
The second one show the next problem, which is probably derivated from the first. See what happens to the tonearm when it starts playing. It skews in the direction of the record and looses all parallelism with the sensor arm. Obviously the carrier can not keep up with the tonearm! It does move, but VERY slowly, much slower that the record demands, hence the tilted tonearm.
https://www.youtube.com/watch?v=nOlgLJEhuss
And last but not least, I have illustrated with a very brief video the drive belt bearing, which makes more noise than it should (I believe).
In the videos you will see the carrier screw that moves the tonearm, it is full of old grease! I cleaned that and lubed it with sewing machine oil. No improvement.
https://www.youtube.com/watch?v=hnUuAU6nO6g&feature=youtu.be
What could be happening?
Thank you, guys
I have looked at the servo very closely and it DOES indeed seem to turn more than the belt does! So i imagine there is a lack of movement, because the bearing does skid under the belt a little bit. Maybe that could fix both the ff/rewind problems as well as the skewed tonearm?
Been doing some reading about the belts for this servo, but I haven't seen many agreements about where to get them other than Martin Olsen (Dillen)? I have PM him.
What do you guys think?
Cheers
Item 1, if the belt isn't slipping check the slow side transport adjustment which adjusts the speed for manual tracking of the record.
item 2, I suspect the lamp in the arm sensor is gone which is why the carriage is not moving, the arm sensor lamp is under the arm at the back of the unit.
drew
Dillen gave me this suggestion:
"Adjust the opto interrupter diaphragm for the tracking control, it sits at the foot of the carriage. Service manual page 3-5."
This totally solved it!
Thanks guys!!
Which is the transport adjustment switch?
