Hi all! I have just a recent problem with my Beosound 9000 with it's vertical stand. Last week everything was working pefectly.
Since yesterday when I turned my BS on, nothing's happens, except the yellow light on the first CD, and the red light of this first CD turn on (instead of the standby one). But that's all!
CD doesn't mount and rotate. I use manually the button on the side for the second CD, nothing happens. With the button "Open": nothing!
I use the Beo4 for "Radio": nothing on the display, only the first red CD light.
In the bathroom, when I now choose "Radio": no sound, and nothing happens too on the BS9000 except the light...
Is it a big problem, doctor ? My 6 CD's are in jail...!
Thanks for any advice
Samsung PS64F8500, Beosound 9000, 2 x Beolab 1, Beolab 7-4, Beolab 2, 2 x Beolab 4000, Beolab 3500, 2 x Beo 4, Emotiva UMC-200, Oppo BDP-103D, Panasonic DMR BCT-730; Harmony Ultimate.
Typical psu faillure.
Mk1 and mk2 are not supported anymore by B&O. So some of them end up with me for fixing the psu's and/or lasers.
So, I hope you have a mk3 version.
However, you can lift the glassdoor by using some force. That way you can take your cd's. Only the one in the mechanisme can't be taken out.
Thanks for answering Beobuddy,
Maybe as a newbee: what is the "psu" ?
I have this model:
kallasr:it is mk3 and psu is a power supply unit (as far as i know....) Ralf
Ralf
OK, it means it could be possible to contact a B&O reseller to repair my BS9000 ?
l_avocat: OK, it means it could be possible to contact a B&O reseller to repair my BS9000 ?
If you have a reseller or someone you know who can do this type of work.
Otherwise use a B and O dealer who will have a repair facility.
valve1: If you have a reseller or someone you know who can do this type of work. Otherwise use a B and O dealer who will have a repair facility.
OK i will go to the next B&O dealer, we still have one in the region (2 have dissapeared..)
Thanks a lot all!
Hello!
Have you already tried to unplug your BS? It's worth a try!
Best regards Elamr
Best regards Elmar
Not at all. But you're right, I should. I try at once!
f5434964: Hello! Have you already tried to unplug your BS? It's worth a try! Best regards Elmar
It works! Thanks a lot
PS: why don't we found in the B&O user manual a "troubleshooting" page..?
You may give me your adress, and I'll send you a bottle of good swiss wine (red or white?)
l_avocat: It works! Thanks a lot PS: why don't we found in the B&O user manual a "troubleshooting" page..? You may give me your adress, and I'll send you a bottle of good swiss wine (red or white?)
Nice one and well done Elmar
Thanks ;-))
Glad to read that the problem from the BS9000 was easily solved.
The psu is controlled by the processor. Different parts of the BS9000 are activated or deactivated when needed by the processor.
So probably by unplugging the BS9000, the processor was resetted.
If the problem occurs again and more often, unplug the BS9000 to prevent more possible internal damage.
