Is Beosystem 4 an AV RECIEVER or should i buy av reciever (marantz,etc)for beolab 14 speakers 5.1 movies only? You know dts-hd,true HD original blurays?
Please help me out i do not wanna pay 4k for something that might not be it.
In the b&o store they said i gain more surround quality with reciever instead of beosystem 4 so now i am lost :(
BS4 supports the following formats:
Multichannel PCM, Dolby Digital, Dolby Digital Plus 7.1, DTS Digital Surround, HE-AAC v1 and v2, LC-AAC, mp3, WMA, WMA lossless, FLAC.
.. and i will have to disagree with your B&O dealer. If you currently own a BL14 5.1 setup you will gain an excellent surround experience with BS4.It have all the features you would want, and everything in regards to BL14 is allready programmed into it.
On top of that, the BS4 is packed with a lot of features that you won't gain from a traditional AV-reciever (USB/HDD playback, PUC control etc.)
Basically it does not matter where the decoding of rhe HD-sound formats take place.
Any for the HD-sound format certified decoder will do the same job.
Of cource the BL14-set will work well with the BSys4 - the dealer who says otherweise digs his own grave!
The BL14-combo is great for movies and multichannel sound.
If you are more into 2-channel listening (stereo/music), you should rather choose BL17's (or whatever you can afford).
