Beogram 5005 and Beomaster 6500
This post has 21 Replies | 1 Follower
pepps
Kent, UK
Posts 116
pepps Posted: Wed, Mar 5 2014 12:40 PM
Hello,
What's the best way to run my BG5005 with my newly acquired BM6500?
I understand the BM is not equipped with an RIAA.
How can I fit an RIAA and retain datalink functions?
Looking forward to any tips.
Kind regards,
Julian
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The easiest way is to sell the BG5005 and buy a BG3500, 4500, 6500 or 7000
Regards Graham
BO
Halmstad, Sweden
Posts 728
BO replied on Wed, Mar 5 2014 3:08 PM
http://www.iconic-av.co.uk/item/1321/RIAA+Pre-Amplifier+with+Datalink+for+BeoGrams/
OR
http://www.soundsheavenly.co.uk/bando-riaa.htm
//Bo.
A long list...
pepps
Kent, UK
Posts 116
pepps replied on Wed, Mar 5 2014 3:08 PM
joeyboygolf:
Thanks.
Disappointing but sure I can see that's the most straight forward idea.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Or sell the BM 6500 and pick up a BM 5000 or 5500.   Keep in mind the BM 5000 needs a different MCP/hand-held remote vs. the 5500.   The BG 3500/4500/6500/7000 are rare and in-demand since they have built-in preamps.
Dennis
Denmark
Posts 627
Dennis replied on Wed, Mar 5 2014 5:06 PM
Or you could install one of the original RIAA preamplifier accessories made for BeoMaster 6500/7000. That would also retain Datalink functions! Wink
Only requires a bit of soldering and cutting two jumpers on the preamplifier board (PCB3).
/Dennis
joeyboygolf
Posts 4,188
Dennis:
/Dennis
But the RIAA accessory board is as rare as rocking horse droppings!
Regards Graham
Dennis
Denmark
Posts 627
Dennis replied on Wed, Mar 5 2014 6:15 PM
I must be lucky then - I'm pretty sure I have a NOS one with original installation guide somewhere. Wink
PM me if you're interested, Julian.
/Dennis Smile
pepps
Kent, UK
Posts 116
pepps replied on Wed, Mar 5 2014 11:51 PM
bos00:
OR
Thanks BO. Love the inconicAV mini amp!
pepps
Kent, UK
Posts 116
pepps replied on Wed, Mar 5 2014 11:54 PM
mediabobny:
Thanks Bob. I have a BM5500 but fancied a change.
pepps
Kent, UK
Posts 116
Loudspeaker:
/Dennis
Now this sounds like a plan!
pepps
Kent, UK
Posts 116
pepps replied on Wed, Mar 5 2014 11:55 PM
joeyboygolf:
Regards Graham
Dang it.
pepps
Kent, UK
Posts 116
pepps replied on Wed, Mar 5 2014 11:57 PM
Loudspeaker:
/Dennis
Thanks - I'll be in touch. Have an issue with a quiet right channel on 'speakers 1' to rectify first :-/
Dennis
Denmark
Posts 627
Dennis replied on Thu, Mar 6 2014 7:24 AM
Is it quiet like in very low sound or like in completely no sound at all? If both channel sound normal on "'speakers 2', then the output amplifier should be OK.
It could be caused by a stuck mute relay - quite common fault - but it would usually go silent in both channels on 'speakers 1' then.
/Dennis
joeyboygolf
Posts 4,188
pepps:
Loudspeaker:
/Dennis
Probably the "Mute" relay. Try turning the volume up and you may find that the quiet channel suddenly re-appears.
Even if the right channel does not come back to life it is still probably the relay.
Very common, I have changed several
Regards Graham
pepps
Kent, UK
Posts 116
pepps replied on Thu, Mar 6 2014 12:29 PM
Thanks MediaBob - I would rather stay away from the 80s BM5000. I had one previously but swapped it up for a 5500 to enable use of the beautiful Beolink 1000 controller.
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Mar 6 2014 12:34 PM
There's also the issue of the aluminum finish mismatch (if the units are aluminum coloured). Perhaps it doesn't matter to everybody, but I couldn't stand looking at the brushed 5000/5500 series and polished 6500/7000 series units mixed in the same stack.
As to the muting relay problem, try operating the muting function dozens and dozens of times on the remote. Sometimes it cleans the contacts and it starts to work again. There's an equal chance that it doesn't though, and then the only options are to replace the relay, or move the speakers to the no.2 connectors and live with the power-on pops (and no muting function).
--mika
pepps
Kent, UK
Posts 116
pepps replied on Thu, Mar 6 2014 12:44 PM
Hi Dennis and Joeyboygolf,
Quiet as in no sound at all through the right channel. Sorry, should've been clearer when I made my last comment.
I think you're right though. I tested the sound in the kitch running through MCL and I'm getting a good stereo response.
I only picked the BM up last night so by the time I drove it home and set it up it was too late to play loud music.
However I did hear some crackles of music coming through the quiet (right) channel once I buzzed into the 50s on the volume scale.
Judging by the little trace of rust on the mains fuse I suspect it's been in storage for a while. I remember my BM5500 was similar when I first played it - it'll warm up and hopefully when I get home tonight I can give it a proper trial.
The most pleasing thing about my lovely shiney 'new' BM6500 is the headphone stage works properly (my BM5500 didn't pan left/right correctly through headphones). It brings a lovely new level of punch and clarity to my Grado headphones - very good indeed.
Another bonus about the 6500 over the 5500 is when I cycle through the 'sound' menu the loudness feature appears as an option, unlike on the BM5500 where you can only activate it by using the crafty shift-reset button on a Beloink 1000 (I didn't have a MCP).
So once I get dual channels working on passive speakers 1 I'll be keen to find myself an RIAA  Big Smile
pepps
Kent, UK
Posts 116
pepps replied on Thu, Mar 6 2014 12:53 PM
Mika thanks for your feedback - I missed it in the rush of replies Smile
You'd have a shock if you saw the mis-matching I'm rocking at home! Not only do I have the brushed finish of the BC5500, then on top of that the polished finish of the BM6500 but on top of that I have a BGCD3500 (grey finish)!
I can almost hear you screaming in terror!  Laughing
Regarding the relay tips - appreciated. I'll see how it plays when I get home tonight. As I've already heard a little blip of music from the quiet channel when I experimented late last night I'm sure it'll pop back into life with a little encouragement. If it resists I'll keep switching the mute relay on and off as you suggest.
pepps
Kent, UK
Posts 116
pepps replied on Thu, Mar 6 2014 9:51 PM
Graham, good spot. T'was indeed in need of a little gentle encouragement with the volume control. All working fine now. Sounds a lot clearer than my BM5500 too. Must be the comparative newness of it - sounds airy and fresh, if that makes sense?
I'll give it a couple of days...
pepps
Kent, UK
Posts 116
pepps replied on Sun, Mar 9 2014 1:57 AM
Just as an an update for everyone really, just had this back from Iconic AV:
Hi Julian,
Thanks for your email, unfortunately you have found an old link we no longer sell the riaa pre-amplifiers. Sorry I cant be of more help.
Kind Regards
Tara Shale
Iconic-av
bos00:
OR
//Bo. Beocenter: 9500, 2x7700, 7007, 2x2200, 1800, 3500, 3x9000. Beosound: Ouverture, Century. Beosystem: 2500. Beomaster: 1400K, 901, 3000, 4500, 2x5500, 8000. Beogram: RX2, 9500, 9000, 8000, 2x5500, 1200, CD50, CD4500, CD5500. Beocord: 2x5500, 9000, 4500. Beovox: 2x Penta, S80.2, 2xS60, S45, RL60.2, RL 45, 2xC30, C75, CX100, Cona, 3000 (1970). Beolab:2xPenta MkII. Beolink: 6x1000, 5000, 7000, MCP5500, Beocenter terminal. MCL: a lot.
joeyboygolf
Posts 4,188
Some years ago there was a company that made a copy of the B&O RIAA that you could fit inside your BG5005.
It would appear that datalink was implemented,
I have found some installation instructions here
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=16&ved=0CFAQFjAFOAo&url=http%3A%2F%2Fwww.mb-el.net%2FInstallation%2520guide%2520for%2520BeoGram%252059XX%2520EN.pdf&ei=BCgcU9C7EMHChAfXroGoCQ&usg=AFQjCNGjYrTl4hoWCDI3Ac6IuM0NJxsz4g&bvm=bv.62578216,d.ZG4
However, the company may no longer exist.
I believe that it was a Scandinavian company so one of our colleagues over there may know of it.
Regards Graham
Page 1 of 1 (22 items) | RSS
