BV3 won't switch on
This post has 7 Replies | 0 Followers
Bouncer
Posts 20
Bouncer Posted: Thu, Mar 6 2014 10:00 AM
Hi all,
I have had this BV3 from new for seven years with no problem.
Recently I switched off the TV by means of the bottom right mechanical switch to do some wall painting.
When I wanted to switch on the TV again, to my horror, it won't come back on!
I think it is just the switch that is not working but are there any other ways to revive the TV before I call in the maintenance to charge me eye watering price just for something simple?
Bouncer
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Mar 6 2014 12:22 PM
Perhaps it is asking for the PIN code - this security feature can be initiated when the TV has been switched off from the mains for some time, but you should see a PIN request at the top of the screen.
Bouncer
Posts 20
Bouncer replied on Thu, Mar 6 2014 12:35 PM
Thanks Guy.
It won't even power on so I don't think it is the root of the problem.
There is not even the red light so I think so how I killed the switch.
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Mar 6 2014 1:26 PM
Check the fuse in the mains plug first!
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Mar 6 2014 3:21 PM
If the set was moved is it possible that the mains lead is slightly out of the back of the set? Wouldn't be the first time ;-)
Opman
Bouncer
Posts 20
Bouncer replied on Sun, Mar 9 2014 6:49 AM
Replaced the fuse and checked the plug.
still no luck
Bouncer
Posts 20
Bouncer replied on Sun, Mar 9 2014 6:50 AM
still no luck
Bouncer
Posts 20
Bouncer replied on Sun, Apr 20 2014 5:55 AM
Thanks for all for the tips.
I decided to replaced the BV3 with my old 32" BV7 from the living room and bought a 40" BV10.
Sad to see the BV3 go.......
Page 1 of 1 (8 items) | RSS
