Beovision 11 and sky fibre router
This post has 9 Replies | 1 Follower
thorne
Posts 315
thorne Posted: Fri, Mar 7 2014 3:32 PM
I have been told that the 11 will not function correctly when connected to this router.  Any comments/suggestions would be most welcome
i should add that I have sky router wired to an Apple Time Capsule, which is in bridge mode.  Does this change the situation at all?
moxxey
South West, UK
Posts 5,359
moxxey replied on Fri, Mar 7 2014 4:06 PM
thorne:
Use the Time Capsule as your wireless router and turn off wifi on the Sky router? Then connect to the Time Capsule from your BV11. Works for me.
I've recently switched to powerline adapters though. Far quicker and essential for streaming ripped Blu-ray content from my NAS drive, via ethernet.
thorne
Posts 315
thorne replied on Fri, Mar 7 2014 6:20 PM
Thanks, so are you saying what I was told is correct, that the sky router does not function with the 11?  Also, let me explain my set up more thoroughly:
i have aven indeed disabled wireless on the sky router, using the TC as my wireless router
I also use power plugs to hard wire the sky router to the Time Capsule, because the TC is in a different room from the TV and the sky router
if I bought the 11, and plugged it into the sky router, have I described your set up, which you say works for you?
thanks
thorne
Posts 315
thorne replied on Sat, Mar 8 2014 4:40 PM
One other question, can the 11 be connected to the internet wirelessly?  This would help enormously as I am running out of ethernet sockets!
rob08
Posts 209
rob08 replied on Sun, Mar 9 2014 12:56 AM
Yes it can
thorne
Posts 315
thorne replied on Sun, Mar 9 2014 8:36 AM
Excellent.  Thanks for that.  And what's your take on my set up explained above?  Should I be concerned about having a sky router?
rob08
Posts 209
rob08 replied on Sun, Mar 9 2014 8:43 AM
I think it will work with your sky router. BUT as you have a time capsule, which is a much better router than the sky router (probably). I would put the sky router in bridge and use TC as router connected to bv11
thorne
Posts 315
thorne replied on Sun, Mar 9 2014 8:51 AM
Problem is the TC is not in the same room as the TV
Also, how do I put sky router into bridge mode.  At the moment it's the TC which is in bridge mode and that's dead easy to do!
Millemissen
Flensborg, Denmark
Posts 14,680
thorne:
"running out of ethernet sockets".
There is a remedy for that - it is called a 'switch' Big Smile
thorne
Posts 315
thorne replied on Sun, Mar 9 2014 12:48 PM
Thanks, I am aware of that possibility, but a switch entails yet another box and a need for another spare socket!
Page 1 of 1 (10 items) | RSS
