NRadio on BeoSound4?
Michael
Atlanta
Posts 98
Michael Posted: Sun, Mar 16 2014 1:59 PM
I've been re-orginizing a system recently and ended up having something odd happen.
Set up: BeoSystem3 V.option   /  Beosound4: A.option  /  Various Active link rooms
I accidently hit N.Radio in a link room and it activated my BeoSound 4 which displayed N Radio on the display.
Now I'm aware that Nradio and Phono are the same code ( the reason I even hit it was due to a recently unconnected BM7000) but why would the Beosound4 respond?  It supports neither Phono nor Network Radio ( as far as I know) connectivity.
This is a North American model.  Does it have something to do with DAB radio which is not supported in North America?
kallasr
Germany
Posts 2,562
kallasr replied on Sun, Mar 16 2014 2:24 PM
I am pretty sure the Beosound 4 supports n.radio (as Beosound 9000, Beosound 3000 - with min. sw levels)
Ralf
olvisab
Posts 1,391
olvisab replied on Sun, Mar 16 2014 4:08 PM
kallasr:
Ralf Beolab 5000/Beomaster 5000 driving Beovox S45.2 with Stands Beosystem 7000 black on F1000 (3 cubes) attached to Beovox 5000 (flat panel), remote: Beolink 1000 Beolink Active (attached to Beomaster 7000 via Beolink Converter 1611) with Beolab 4000s on floor stands, remote: Beo 4 DTV Pioneer AVR VSX-LX60 with Beolab 8000 (Fronts), Beolab 4000 with small brackets (Centers) and Beovox CX100 (Rears - using a Teufel Rearstation 4 for wireless connection) and a KEF PSW2500 active subwoofer - Screen:Pioneer Kuro PDP-LX5090H.
Beomaster 6500 or 7000 white STILL ON WISH LIST to be set-up with existing Beogram CD 5500 white - this system might replace the Beolink Active
Thread about Howto setup a NON B&O amplifier with Beolabs (3.1 or 5.1 surround setup with Pioneer Kuro + Pioneer AVR)
You are right ralf
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Michael
Atlanta
Posts 98
Michael replied on Sun, Mar 16 2014 8:32 PM
Thanks guys.  I guess my question could of been phrased a bit differently.  I realize that it's not as much of whether it supports it, but rather:
Why would a Beosound of any kind respond to a command for a service that is not:
1. Active internally ( CD AMEM, Radio).
2. Not directly connected (N.Radio/Phono, etc to a BeoMaster).
3. Not anywhere on the Masterlink network and therefore not advertising itself as even available.
Is this normal?  I would assume it would just pass the command on and/or ignore it altogether.
DoubleU
Posts 562
DoubleU replied on Sun, Mar 16 2014 9:19 PM
N.Radio is active internally. It just doesn't have a dedicated hardware button.
Does your BS4 respond to an A.AUX-command, even though there is no signal on the RCA-in?
Does it respond to a CD-command when there is no CD inside?
I believe it does.. What's the problem?
Michael
Atlanta
Posts 98
Michael replied on Sun, Mar 16 2014 10:51 PM
There's no problem DoubleU.  Just a curiosity about something that seemed a little odd.
Obviously, it would be "answering" A.Aux and CD commands from the network as those are internal sources.  By saying that a BS4 has N.Radio functionality "active internally" are you simply saying it has the ability to recognize and receive audio from N.Radio sources ( Beoport, etc.)?
Or are you saying it has actually has the ability to BE a N.Radio source?
If you mean the latter I guess I would find that surprising unless N.Radio commands were being utilized by the optional DAB modules in some markets.  Is there any other way that a BS4 could be a N.Radio source?
I hope I'm not being thick here, I really do just want to understand.
DoubleU
Posts 562
DoubleU replied on Sun, Mar 16 2014 11:17 PM
No problem! I didn't understand the question so it seems, but I see what you mean now. For usability it doesn't make a difference. If you select CD, A.AUX or N.Radio, and there is none of them available, the BS4 will wake up, but doesn't know the source is empty. I think that's the best way to understand.
No, the BS4 doesn't have the ability to be a N.Radio source. Like you said, only receive audio from a N.Radio source. BeoPort for example.
Page 1 of 1 (7 items) | RSS
