I've been re-orginizing a system recently and ended up having something odd happen.
Set up: BeoSystem3 V.option / Beosound4: A.option / Various Active link rooms
I accidently hit N.Radio in a link room and it activated my BeoSound 4 which displayed N Radio on the display.
Now I'm aware that Nradio and Phono are the same code ( the reason I even hit it was due to a recently unconnected BM7000) but why would the Beosound4 respond? It supports neither Phono nor Network Radio ( as far as I know) connectivity.
This is a North American model. Does it have something to do with DAB radio which is not supported in North America?
kallasr:I am pretty sure the Beosound 4 supports n.radio (as Beosound 9000, Beosound 3000 - with min. sw levels) Ralf Beolab 5000/Beomaster 5000 driving Beovox S45.2 with Stands Beosystem 7000 black on F1000 (3 cubes) attached to Beovox 5000 (flat panel), remote: Beolink 1000 Beolink Active (attached to Beomaster 7000 via Beolink Converter 1611) with Beolab 4000s on floor stands, remote: Beo 4 DTV Pioneer AVR VSX-LX60 with Beolab 8000 (Fronts), Beolab 4000 with small brackets (Centers) and Beovox CX100 (Rears - using a Teufel Rearstation 4 for wireless connection) and a KEF PSW2500 active subwoofer - Screen:Pioneer Kuro PDP-LX5090H. Beomaster 6500 or 7000 white STILL ON WISH LIST to be set-up with existing Beogram CD 5500 white - this system might replace the Beolink Active Thread about Howto setup a NON B&O amplifier with Beolabs (3.1 or 5.1 surround setup with Pioneer Kuro + Pioneer AVR)
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Thanks guys. I guess my question could of been phrased a bit differently. I realize that it's not as much of whether it supports it, but rather:
Why would a Beosound of any kind respond to a command for a service that is not:
1. Active internally ( CD AMEM, Radio).
2. Not directly connected (N.Radio/Phono, etc to a BeoMaster).
3. Not anywhere on the Masterlink network and therefore not advertising itself as even available.
Is this normal? I would assume it would just pass the command on and/or ignore it altogether.
N.Radio is active internally. It just doesn't have a dedicated hardware button.
Does your BS4 respond to an A.AUX-command, even though there is no signal on the RCA-in?
Does it respond to a CD-command when there is no CD inside?
I believe it does.. What's the problem?
There's no problem DoubleU. Just a curiosity about something that seemed a little odd.
Obviously, it would be "answering" A.Aux and CD commands from the network as those are internal sources. By saying that a BS4 has N.Radio functionality "active internally" are you simply saying it has the ability to recognize and receive audio from N.Radio sources ( Beoport, etc.)?
Or are you saying it has actually has the ability to BE a N.Radio source?
If you mean the latter I guess I would find that surprising unless N.Radio commands were being utilized by the optional DAB modules in some markets. Is there any other way that a BS4 could be a N.Radio source?
I hope I'm not being thick here, I really do just want to understand.
No problem! I didn't understand the question so it seems, but I see what you mean now. For usability it doesn't make a difference. If you select CD, A.AUX or N.Radio, and there is none of them available, the BS4 will wake up, but doesn't know the source is empty. I think that's the best way to understand.
No, the BS4 doesn't have the ability to be a N.Radio source. Like you said, only receive audio from a N.Radio source. BeoPort for example.
