Feels like spamming the forum.
Grrr! Millemissen
Done by a professional (re-?)seller...
Ralf
http://archivedforum2.beoworld.org/forums/p/6494/58318.aspx#58318
Brengen & Ophalen
http://archivedforum2.beoworld.org/forums/p/3398/30875.aspx#30875
Millemissen: Feels like spamming the forum. Grrr! Millemissen
Nearly as annoying as these constant web links in posts where people can't be ar*ed to link up via the toolbar above :)
ie. http://www.google.com -> http://www.google.com
Easy, eh?
So I'm confused now..
I thought ebay links to your own items and using Beoworld as a commercial outlet were frowned upon (apart from paid sponsors).
Do the floodgates open for everyone?
x:________________________
moxxey: Nearly as annoying as these constant web links in posts where people can't be ar*ed to link up via the toolbar above :) ie. http://www.google.com -> http://www.google.com Easy, eh?
Now you tell me how to.
If you can't see a toolbar:
Without the spaces
[ url ]http//www.website.com[ /url ]
No, it isn't!
Jonathan: So I'm confused now.. I thought ebay links to your own items and using Beoworld as a commercial outlet were frowned upon (apart from paid sponsors). Do the floodgates open for everyone?
Seems like it!
Leslie: moxxey: Nearly as annoying as these constant web links in posts where people can't be ar*ed to link up via the toolbar above :) No, it isn't!
I'm with Moxxey on this one! I'm not very keen to read further. If you want others to read what you mean, then put a little effort in it. Not the other way around!
DoubleU: If you can't see a toolbar: Without the spaces [ url ]http//www.website.com[ /url ]
I see the toolbar - but where is the option for that?
You mean like this:
[url]http://www.bang-olufsen.com[/url]
I tried that before - with the same result
How much 'efford' should I put in it?
Sorry, I thought that would work.
If you see the toolbar, highlight a word, go to the toolbar and insert/edit link. Fill in the url, and (optional) set target to new window.
The word you highlighted is now a link.
[ url ]http://www.google.com[ /url ] (minus the spaces) will work - the previous example did not work as it left out the colon between 'http' and '//' so was not a valid URL
Martin.
Spot on!
DoubleU: Sorry, I thought that would work. If you see the toolbar, highlight a word, go to the toolbar and insert/edit link. Fill in the url, and (optional) set target to new window. The word you highlighted is now a link.
There is no 'insert/edit link' in the toolbar!
Sorry for being so numb - this has been irritating me for a long time
Must have a look at the toolbar when using my pc tomorrow to see if it is different there.
DoubleU: Leslie: moxxey: Nearly as annoying as these constant web links in posts where people can't be ar*ed to link up via the toolbar above :) No, it isn't! Yes sir, if you are too lazy to click 2 times to provide a working link, I wont bother reading it. I'm with Moxxey on this one! I'm not very keen to read further. If you want others to read what you mean, then put a little effort in it. Not the other way around!
riverstyx: [ url ]http://www.google.com[ /url ] (minus the spaces) will work - the previous example did not work as it left out the colon between 'http' and '//' so was not a valid URL Martin.
I had the colon in at first, then let it out because it was let out in the first example.
Now it is in again (have a look) - but no changes anyhow.
I know this code - and more - I use them all the time, when I write on the danish 'Hifi4all' forum.
No problems there.
Hmm, not sure what your browser is doing then, but looking at your post in the html view you have ended up with the following:
[<span>url]http://www.bang-olufsen.com[/url]</span>
whereas when I type [ url ]http://www.bang-olufsen.com[ /url ] (without the spaces) I end up with the open bracket after the <span> tag, and it is correctly interpreted as a link.
Maybe it's a bug in whichever browser you are using, or maybe it was because you were editing a previously post rather than typing a new one - very bizarre!
Millemissen: riverstyx: [ url ]http://www.google.com[ /url ] (minus the spaces) will work - the previous example did not work as it left out the colon between 'http' and '//' so was not a valid URL Martin. I had the colon in at first, then let it out because it was let out in the first example. Now it is in again (have a look) - but no changes anyhow. I know this code - and more - I use them all the time, when I write on the danish 'Hifi4all' forum. No problems there. MM
Whats your problem MilleM, Copy the link, past: http://www.hifi4all.dk/forum/forum_posts.asp?TID=66882&PN=1&TPN=87, highlight it or write a word, highlight it, click link in menu, past link to URL. click insert.
Søren Mexico: DoubleU: Leslie: moxxey: Nearly as annoying as these constant web links in posts where people can't be ar*ed to link up via the toolbar above :) No, it isn't! Yes sir, if you are too lazy to click 2 times to provide a working link, I wont bother reading it. I'm with Moxxey on this one! I'm not very keen to read further. If you want others to read what you mean, then put a little effort in it. Not the other way around!
Now you call me sir? Ever tried to do that with a smartphone, sir? I'm not with Moxxey sir, if you're seeking for some backup. And don't call me lazy. I know exactly how to do that, sir!
That's the problem, Soren. There is no link in his toolbar.
Leslie: No, it isn't!
Yes it is, when you're using an iPad and there's no link to click and most posts contain a link, which isn't clickable. Happens every day.
I've seen posts which *only* contain a link, and it's just a piece of text :)
Leslie:Now you call me sir? Ever tried to do that with a smartphone, sir? I'm not with Moxxey sir, if you're seeking for some backup. And don't call me lazy. I know exactly how to do that, sir!
Sorry, didnt know the problem with the smartphone.
Hi all. The first link to the eBay seller mark r is a pleasure to deal with I purchased my beosound 9000 wall bracket of him and could not fault the service. I watch him as a seller and he currently has boxed 6002 and boxed 8002 which rarely appear on eBay.
I don't know 'mark' - can't say anything about the quality of his services.
My point was, why make 15 (!) post in a row with his offers?
He could have made 1 with them all.
Whether acting this way on the forum (he is a seller, isn' he) is acceptable or not, according to the guidelines of the forum, I'll of cource have to let the admins decide.
For me - as a forum-user - it seemed like spamming the forum.
Søren Mexico: Whats your problem MilleM, Copy the link, past: http://www.hifi4all.dk/forum/forum_posts.asp?TID=66882&PN=1&TPN=87, highlight it or write a word, highlight it, click link in menu, past link to URL. click insert.
Here is a screenshot from my iPad.
As you see the 'link/unlink' buttons are greyed out - not active.
Why, I don't know. Other elements in the toolbar work well
In Safari on my Mac they are active though - as you see below.
So, this has nothing to do with being lazy or not wanting to......
What options do I have:
Sitting at my desk with my Mac all day long? No, that won't happen! The iPad has been invented - it is with me wherever I am in the house.
Not posting URL's at all? That would be possible (is it really that hard to 'copy/paste' a URL into a new tab?)
Keep on searching for a solution. That'll take time, perhaps? The codes I know from other websites don't seem to work on BeoWorld.
Wait for wonders to happen?
So have mercy on me, kære Søren
Greetings Millemissen
I can confirm that it's impossible to make an active link with an ipad.
It don't work with the APP nor the browser.
EDIT: link below is made in an iPad. Use chrome as your browser.
http://www.test.se
//Bo.A long list...
Millemissen:So have mercy on me, kære Søren
Sorry Millemissen, didnt realize that there was a problem there, I hope someone can come up with a solution.
Søren Mexico: Sorry Millemissen, didnt realize that there was a problem there, I hope someone can come up with a solution.
I can
At least something I can live with - and hopefully others too?
Tested another code (that works on the danish Hifi4All-forum).
Goes like this:
Push the button or copy/paste the URL: http://www.bang-olufsen.com/da - it's your choice
BO: EDIT: link below is made in an iPad. Use chrome as your browser. http://www.test.se
Hi Bo,
thanks - I did not get that far, before I found the (above/page2) solution.
And I do not like the thought of having to switch to another browser because of that issue.
