No, those are between the mech's main chassis and the mobile part (261). They don't appear in the exploded view.
Here the red arrows show where they are.
Jacques
tournedos: I believe they are there just as courtesy items from the factory - anybody who starts to work on these must have balls (I'll get me coat)
(I'll get me coat)
But seriously, although a bit daunting, they are more time-consuming than really complex.
Thanks for your great advice! and the exploded drawings! I went ahead and took the drive out. I wrote a detailed account of the procedure on my beolover blog at:
http://beolover.blogspot.com/2014/10/beocord-5000-47164715-removing-drive.html
More later...Saturday afternoon business is calling now...;-)
Rudy
http://beolover.com
Keep them coming Rudy, I still have the BC 5000, that Rick gave up on, here, I always pas it giving it the "dont yell at me" look, but one day I will get to it.
Rudy, if you had unscrewed the solenoid first, there would have been nothing else to do that rotating the plunger to extract the lever!
Hi Jacques,
This meaning you would have separated the solenoid from the drive mechanism by removing the two horizontal screws that hold the entire solenoid assembly it in place or the two vertical screws that just hold the solenoid to the bracket that is bolted to the drive?
Thanks!
Exactly!
Next time I'll do that...;-).
So while I am waiting for the proper replacement belts from Martin (thanks!), I thought I use the time to write up my recent experiences with converting the Beomaster 6000 to LED scale illumination...what I assumed would be a one-weekend design effort (some 3D printing and LED soldering) turned into a pretty interesting design experience.
Pt. 1 of the story is posted at my beolover blog: http://beolover.blogspot.com/2014/10/beomaster-6000-4-channel-2702-led-based.html
Here is a pic of the FM dial of my unsuccessful attempt with amber LEDs:
And here is Part 2 of the Beomaster LED story:
http://beolover.blogspot.com/2014/10/beomaster-6000-4-channel-2702-led-based_17.html - enjoy!
Here a pic of the set-up implanted into the Beomaster (of course totally non-destructive and fully reversible...;-):
Nice and proper work as Always.
/iDkc
http://tinyurl.com/qj9cjsf
HarryPierce: And here is Part 2 of the Beomaster LED story: http://beolover.blogspot.com/2014/10/beomaster-6000-4-channel-2702-led-based_17.html - enjoy!
Awesome!
--mika
I do admire your work, quite impressive, and I appreciate that you are having a good time.I also like that what you do is fully reversible.
But you put a truckload of hours into this and you put another truckload oftechnology at work to achieve something that looks as it did originally.We have a saying in Denmark; "Don't cross the stream to get water".B&O achieved the same result by using simple lamps.I think, I would just have fitted new lamps and replaced broken sockets as needed.But that's just me...
Hi Martin,
The journey itself is the destination of my travels...;-)...just having too much fun with this stuff.
Cheers,
Here is Part 3; it discusses the circuits and the microcontroller code...that is it for now.
http://beolover.blogspot.com/2014/10/beomaster-6000-4-channel-2702-led-based_4.html
Enjoy!
A stroke of Craigslist luck, today! I was able to buy an almost pristine-looking Beosystem 6000! This will keep me busy for a while (of course it is not working, but that is where the real fun is...;-). I posted a couple of pics on my blog:
http://beolover.blogspot.com/2014/10/an-early-christmas-beosystem-6000-is-in.html
HarryPierce: A stroke of Craigslist luck, today! I was able to buy an almost pristine-looking Beosystem 6000! This will keep me busy for a while (of course it is not working, but that is where the real fun is...;-). I posted a couple of pics on my blog: http://beolover.blogspot.com/2014/10/an-early-christmas-beosystem-6000-is-in.html Enjoy! Rudy
I just love those things. Keep up your good and important work!
/Kcid
Love it is! In the meantime the Beocord 5000 belts arrived in my mailbox from Martin (thanks much!).
I just put them in. It seems that most of the deck may now be working, but I am in process of playing with it...I made a video about the belt exchange:
http://beolover.blogspot.com/2014/10/beocord-5000-47154716-replacing-belts.html
Here an impression:
A video that's worth a thousand words! Well done Rudy!
Thanks Rudy, a great help and well explained and demonstrated.
Dave.
Thats a real good one! I´ll bookmark it!
Thank you!
Another great video tutorial. Thanks!
Regarding the Beocord 5000, I have read where people claim that deck starts to eat tapes when it gets out of adjustment. Is that something that is fixed with new belts? Or are there other adjustments that are necessary to make sure the BC5000 doesn't get to that point (of eating tapes)?
-sonavor
Hi John,
I've got two, and so far they haven't damaged and tapes in two-three years!
chartz: Hi John, I've got two, and so far they haven't damaged and tapes in two-three years!
Good to know. I don't recall my BC5000 ever eating a cassette tape but I haven't used the deck since 1982. That is the deck I plan on rebuilding.
HarryPierce: Yep, the 5000 must work, too! Just ebayed a service manual for my 4716 type. Were does one get the belts? Thanks! Rudy
As I said...it almost worked...;-). When I tried it out after replacing the belts, it turned out that there was a problem in the electronic switch that made it rewind very slowly, and caused inconsistent Auto Stop and Pause functions.
Details: http://beolover.blogspot.com/2014/10/beocord-5000-47154716-slow-rewinding.html
Maybe now it is time to try making a record!
I will eventually get an BM6000Quad for refurb in two month.It does scare me to change the belts considering the risc of destrying those clips, as I have no possibility to 3D printAnyone else with experience of these clips ?Christian
My re-capped M75 are my precious diamonds.
Christian Christensen: Anyone else with experience of these clips ?
Yes, Rudy, aka Beolover!
Beolover: Yep, the 5000 must work, too! Just ebayed a service manual for my 4716 type. Were does one get the belts? Thanks! Rudy
I have them.
Dillen, have you had trouble with the clips in the process of exchanging the belts ?
Christian Christensen: Dillen, have you had trouble with the clips in the process of exchanging the belts ?
No.But that's probably because I don't squeeze them so they break.
