Beolit 12 reset
This post has 9 Replies | 1 Follower
Simonbeo
Posts 1,451
Simonbeo Posted: Mon, Mar 24 2014 4:24 PM
I've tried unsuccessfully to set up beolit 12 and first set-up is not available again . Can it be reset to perform set up again ?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Simonbeo
Posts 1,451
Simonbeo replied on Mon, Mar 24 2014 9:27 PM
Or does it need a software update ?
whoops . Otherwise I'm the first person to get the setup wrong .....
symmes
Posts 247
symmes replied on Tue, Mar 25 2014 12:13 AM
Simonbeo:
http://www.bang-olufsen.com/en/customer-service/faq
Simonbeo
Posts 1,451
Simonbeo replied on Tue, Mar 25 2014 6:47 AM
Thanks symmes
Simonbeo
Posts 1,451
Simonbeo replied on Tue, Mar 25 2014 6:55 PM
Take back all I said about plug and play!
you pay £600 to get told it might not connect so you need an Ethernet cable and download software update .....
Mark
London
Posts 1,063
Mark replied on Tue, Mar 25 2014 10:47 PM
stick with it, yes it is completely annoying you have to Ethernet all firmware updates and the way the control buttons work (the amount of times I have accidentally switched the 12 off when I rest my iPhone on its top then blindly reach for it) but the sound it emits when working out ways all these idiosyncrasies.
I use my Beo4 to control the sound level as it's more user friendly than via iPhone or units controls.
Simonbeo
Posts 1,451
Simonbeo replied on Wed, Mar 26 2014 5:57 AM
Yep. Resorted to wire connection for the moment . Superb sound and as you say the Beo 4 controls it !
Not just volume ; other functions on Spotify such as next track . Trouble is the remotes signal goes to the Beocenter6 in the next room if you're not careful.
oh, and the funniest thing is that the sales chap in a London B&O shop told us that the Beolit 12 did not work with the Beo 4 and that you need the A8 if you want that !
we walked down the road to Peter Jones and bought the B12 there
Mark
London
Posts 1,063
Mark replied on Wed, Mar 26 2014 12:13 PM
never knew about Spotify next track ..... thanks for the heads-up.
the more I learn about B&O the more I realise I do not know.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Mar 26 2014 2:45 PM
While I find it a bit inconvenient, I can understand why B&O makes you have to use a wired connection to update firmware. It's awfully easy to get a system that bricks itself if firmware updates are interrupted before complete, and given the unreliability of too many wireless connections it makes sense to require a wired connection for this.
If you're having connection problems with wireless for music streaming that's another matter. I recently went thru a hair pulling experience trying to find out why I had streaming issues to my Playmaker. For me it turns out that I had a competing application on my laptop that was causing network access issues. Once I deleted that app I stream flawlessly. There can be a lot of different causes for streaming issues, but a couple of main ones are the router (a lot of inexpensive wireless routers are total crap), and the other is interference from neighbors wireless setups. If you search around the site here you'll find how a lot of this has been handled by others and hopefully solve your problem.
Jeff
Simonbeo
Posts 1,451
Simonbeo replied on Thu, Apr 3 2014 11:34 AM
One last attempt before we take the Beolit back to the shop. The Airplay function will not sync with the iPad even after software update and reset of the speaker . The sound is great but shouldn't need a wire connection !
ideas anybody ?
Page 1 of 1 (10 items) | RSS
