Beogram 5005 and MMC4: dull sound
This post has 50 Replies | 2 Followers
Søren Mexico
Mexico City
Posts 6,411
I did an experiment, I have an ABBA album , "The singles", played Voulez-vous. First on the TX2 with MMC4, through my Onkyo to Bvox 3702, first flat and then adjusted the bass to +5% and treble to +10%, thats the way I like it. I then connected my P45s to my 5000 stack, put the same MMC4 cartridge on the BG 5000, played same song, to get same sound as on the TX2 (5%bass,10% treble) I had to play flat on the 5000 stack, whereas if I use the SMMC4 on the BG 5000 I have to turn down the treble to - 1 line in the display (must be minus 10-15%).
The BG 5000 is my preferred BG
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Apr 5 2014 9:07 AM
Conclusion: there is nothing wrong with my set-up, my hearing must be at fault, curtailing the higher frequencies. I have tried many configurations and the result is always the same. The MMC4-equiped 5005 lacks treble, while CD sounds fine on the Beosystem. But treble is already at +3!
I insist that the first recording (from my LP) sounds flat and uninspiring to my ears, as does any record on this deck.
Perhaps the "fierce", or CD-like treble of the SMMC suits my hearing better. Live, unamplified music is a no-brainer though, but it is warm too!
Some time ago I attended a live performance of Chaplin's Modern Times and the full orchestra was there, but the sound was not very good, I thought. I put that on the acoustics of the concert hall (in Lyon). Perhaps it was just me, my 50-year-old pair of ears.
Rich, you can have your MMC4 back! Thanks again for the loan Smile
Jacques
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Sat, Apr 5 2014 5:47 PM
I still haven't had the chance to do a side by side comparison but I will sometime tomorrow.
Out of interest what stylus are you using on the Beogram 4000? Is it a standard elliptical or one of the shibata type profiles? That would explain the difference in sound..... The shibata's pick-up much more information from the grove particularly in the upper frequencies.
Lee
Ky
LA
Posts 31
Ky replied on Sat, Apr 5 2014 5:53 PM
Excellent music choice, but I agree that it sounds flat, Nick's voice is sounding more goat like than usual. I've been listening to this record a lot on my 4004 lately and agree that yours does sound flat to me too, maybe thats just the stylus? Does raising the treble slider fix the problem at all, or (in your ears) is it just not picking up the highs at all?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Apr 5 2014 6:20 PM
The 4000 uses an MMC20CL or an SMMC20EN.
Yes, raising up the treble slider restores treble, but it doesn't do the sound any good.
Jacques
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
chartz:
It is not possible to do meaningful comparisons if listeners are going to adjust the tone controls to achieve the type of sound that they like.
Because I am generally comparing Beograms and Beomasters which have been prepared for sales stock, I tend to run all my Beomasters "flat".
My comments regarding your samples were made on that basis.
I have an original Rumours on vinyl and on CD and if I play the vinyl on Beogram 3500/4500/6500 or 7000 with MMC4 or MMC2 or Beogram 6000 with MMC20CL, I cannot get the sound to be very different to your original sample. My CD is also very similar.
Hence my comment that I cannot hear anything wrong with your original sample.
Your CD sample is unlike anything I have heard with flat tone controls.
Regards Graham
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Apr 5 2014 6:53 PM
Yes Graham, always flat here too. The two samples were not equalized in any way.
Jacques
Søren Mexico
Mexico City
Posts 6,411
Agree with Graham, but as my hearing is bad I do adjust to the levels I "like", in a couple of weeks I will get my hearing checked, will get back with the results, will be interesting to see which frequencies are involved.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Apr 5 2014 7:13 PM
Well infortunately I am beginning to suspect a problem too. But only with some equipment. So a slightly lively top end does it for me. Clogs are always possible though I guess.
Jacques
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sat, Apr 5 2014 10:40 PM
chartz:
You're very welcome.  No rush.  Whenever you get around to it.
Lee
Posts 734
Lee replied on Sun, Apr 6 2014 2:36 AM
What you can hear is the difference between the various stylus profiles and bonding techniques. The mmc20cl is a line contact stylus so will be much better at tracking higher frequencies (more contact with the grove walls) than the standard elliptical fitted on the mmc4. And the smmc20en is a nude bonded soundsmith cartridge which are renowned for sounding brighter.
The mmc4 sounds fine to me and almost identical to mine.
You should send the mmc4 to axel and have a nude bonded shibata fitted... That will reveal the high end much more than the standard glued elliptical.
Lee
Page 2 of 2 (51 items) < Previous 1 2 | RSS
