Beolab 7-4 with motorized stand
Tintin
Posts 2
Tintin Posted: Fri, Jun 6 2014 5:18 PM
I have a BV 7-40 that comes with a motorized floor stand and Beolab7-4. Recently the TV takes a long time to start up, and we are thinking of changing the TV to a non-B&O TV. Question:
- is there a way to mount a non-B&O TV onto the motorized stand and continue to use the Beolab 7-4? We don't really need the range of motorized movement for the stand.
- if not, is there a way to pair a new TV with the Beolab 7-4?
thanks
olvisab
Posts 1,391
olvisab replied on Sat, Jun 7 2014 1:34 PM
Look at the website of steve (soundsheavenly) you will find a cable for this purpose. He provides me one for a bl7.2.
You can mount another tv on the stand, it shouldn't be too complicated to build a back plate even in wood. It depends of the weight of the tv.
The best is to use a preamp in order to use the bl7.4 has center speaker.
If you don't use a preamp, then you will have the sound of your tv in mono only.
Use a bl7.2 instead and you will have a stereo speaker.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Tintin
Posts 2
Tintin replied on Tue, Jun 10 2014 4:37 PM
Thanks, this is very helpful. Any recommendations on the preamp?
olvisab
Posts 1,391
olvisab replied on Tue, Jun 10 2014 10:08 PM
Hi
Look at the oppo 103d, you have a bluray player built in and 5.1 preout analogic output.
It will treat every hdmi input you will plug into (video and audio).
Page 1 of 1 (4 items) | RSS
