Hiya Guys
I am considering buying the new avant but wanted to know how beoworlders are hiding cables and number of set top boxes and other sources
I think some of you might even have them in another room
photos would be appreciated
Pretty hard to show hidden things
Hi Quader,
There are plenty of good approaches to use here. Personally, I keep all my video sources in a nice cabinet out of the way and control them from the TV via the PUC outputs (with this: http://www.soundsheavenly.co.uk/bando-tvir.htm )
Cable socks ( http://www.soundsheavenly.co.uk/bando-smallsock.htm ) can be used to hide any visible cabling, or you can get these channelled into your walls for a really "clean" look.
I'm sure there will be lots of other ideas coming soon from other Beoworlders......
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Millemissen: Pretty hard to show hidden things MM
Pardon me - I was too temptet
I have my BluRay player, AppleTV Box (with PUC cables), a network switch, a converter, a switchable power outlet and lots of cables in the original B&O cabinet under my BV8-40.
The power cable, antenna, Network- and ML-cable coming through the wall from behind - you only see the cables (in the original B&O rubber thing) running to the frontspeakers and (if you look close) one PL to the rears.
This cable concealment thing is important to me , which is why I would chose the table stand or wall bracket for the new Avant . So much easier to avoid the "tail" of cable which instantly caught my eye at the launch event . Our V1 and beocenter 6 are both wall mounted and the one on the stud wall was easier to achieve .
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Simonbeo: This cable concealment thing is important to me , which is why I would chose the table stand or wall bracket for the new Avant . So much easier to avoid the "tail" of cable which instantly caught my eye at the launch event . Our V1 and beocenter 6 are both wall mounted and the one on the stud wall was easier to achieve .
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
I place our BV on an Ikea cupboard that's part of a bookcase, and placed all the gear inside that - it resulted in a rat's nest of cabling in the original set-up which I have been lately decluttering as there was kit we never used so it is now about half empty !
Ideally I would have the kit relocated by about 4 metres, into a cupboard in another room which houses things like the wi-fi router and backup drives. Might even happen one day !
I will say that with the adoption of HDMI life has become easier than my original setup which had an endless array of cable ropes: VGA, RCA, SCART, and HDMI and 16 power points and a RCA video switching box.
BeoNut since '75
Our V1 in the living room has the Stb etc in a cabinet and the TV is wall mounted just above it . The wall in that room needs to be channeled when we redecorate to put the cable trucking behind the plaster , but it's unobtrusive . On the top floor where it's stud wall the cable has been routed through the wall for the Beocenter 6 and comes out through a shelf which covers the plug etc where the power socket etc are fitted . I considered putting the bluray in the cavity and using the PUC but made a feature of it like a Bauhaus sculpture!
But what is that big tail coming out of the back ?
i know the length of cable required changes according to the stand position but it looks a bit of an afterthought having paid for B&O . (I also know you're looking at a fabulous picture when it's switched on )
That looks great, what boxes have you got attached?
I have heard that you should put them in a ventilated cabinet/cupboard etc
also if you are using a blue ray player then it needs to be accessible to put the disc in
Simonbeo:But what is that big tail coming out of the back ? i know the length of cable required changes according to the stand position but it looks a bit of an afterthought having paid for B&O . (I also know you're looking at a fabulous picture when it's switched
