It seems that the only option for buying MCL cable is a drum of 100m, for which the dealer wants £550! I am going to make my own cable bundle instead with regular speaker cable plus a separate power / data shielded cable. Can anyone see a problem with using a 2-core shielded cable for power and data? The specs for the original MCL cable show that only the data wire is shielded, but a 2-core shielded cable would have the power wire inside the shield as well. The cable run will be ~25m.
I'm in the same boat here. I'm not an expert on cable standards, but I'm thinking the cable's probably a standard part. If somebody knows the DIN or ISO Specification, that would help.
just an idea use a ML cable; should work
I've just been looking at the PowerLink mark 2 cable and I think it would work - is that the one you meant?
edit: I see you mean this one: http://www.soundsheavenly.co.uk/bando-ml.htm which is a lot more expensive, but I guess more future proof.
How about using two speaker cables and a microphone cable, if I remember it right, such a combo has the same characteristics as a mcl cable. Using a powerlink is a bad idea...
Wouter
Wouter: How about using two speaker cables and a microphone cable...
Two speaker cables would carry both audio channels. The microphone cable would have to carry Data, Gnd, and 8.5V DC. Maybe a 3-strand stereo headphone cable? Obviously a single cable would be better from an aesthetic standpoint.
MCL carries the amplified speaker signal. Both Powerlink & Masterlink cables will be way too thin to perform properly in that application with long runs, and be unnecessarily complicated & expensive to begin with.
If you don't find an affordable source for the proper MCL cable, use for the speaker signals whatever cable you would be comfortable using with any passive speaker connection, and something thinner for the data / ground / power. I believe they would be happy in a headphone cable as Brian suggested, it's nothing critical. Still it's a good idea to have the data wire shielded to avoid it leaking into audio signals, just as it is in the proper MCL cable (see http://www.beoworld.org/beotech/wiring1.htm).
--mika
I already have a nearly full 100m reel of speaker cable. I think this screened cable should work for power and data. The only difference from the stock cable is that both power and data will be screened but I don't think that will matter.
Thanks for your advice!
I found this dealer while searching for an MCL Cable: Quality Dream Audio. He seems to have the Y-harness and some assorted lengths of cable. I need a bit longer than what he's offering, but it might be worth a try.
Thanks Brian. I saw that too but I actually need something like 25m. I have ordered a couple of 3 pin speaker plugs from the dealer for £17.
