Connect iPad via Bluetooth to BC9300
This post has 10 Replies | 0 Followers
graemeben
Posts 132
graemeben Posted: Thu, Jan 15 2015 9:42 PM
Hi everyone,
Are there any devices on the market to connect an iPad via Bluetooth to the aux in on a BC9300? Would like this feature for Spotify rather than using the earphone output on the iPad.
Does anyone have a similar set up they can recommend  and what is the quality of the signal compared to wired output?
Thanks,
Graeme.
leosgonewild
Helsinki, Finland
Posts 2,373
Yes. Just buy a Bluetooth adapter with a line out and feed the line to aux input. Sound quality will be lower.
Hardwriter
Posts 51
Hardwriter replied on Thu, Jan 15 2015 10:21 PM
Or use an Airport Express and connect via your wifi network.
leosgonewild
Helsinki, Finland
Posts 2,373
And for better audio-quality, get a Playmaker Smile
Millemissen
Flensborg, Denmark
Posts 14,680
If it is just for Spotify, get a Gramofon.
This device has support for Spotify Connect.
leosgonewild
Helsinki, Finland
Posts 2,373
How is the quality of the DAC in the Gramofon?
Millemissen
Flensborg, Denmark
Posts 14,680
Having made no A/B tests, I really can't tell you.
Sounded not bad, when I tested it at home.
My son has the device now - he is quite satisfied with it.
Will do for most people - and the SQ certainly is miles above that from a Bluetooth device.
But, after all - what quality would you expect from a device in that price range?
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Jan 15 2015 11:43 PM
If I would have a non-Apple smartphone or tablet I would use Bluetooth with this small item:
http://www.amazon.de/Philips-AEA2700-12-Multipair-Empfänger-Bluetooth/dp/B00KMS7HFG/ref=sr_1_3?ie=UTF8&qid=1421364785&sr=8-3&keywords=Philips+bluetooth
You can connect it to AUX-IN of most Beosounds or digital to S/PDIF of many Beovisions. I assume that sound quality will be very good because it supports aptx standard. But Apple still doesn't support aptx it is better to use Airplay together with a Playmaker or Airport Express if you are a proud owner of an IDevice.
Regards
Räuber
graemeben
Posts 132
graemeben replied on Fri, Jan 16 2015 8:03 AM
Hi everyone.
Really like the sound of the Gramofon. Spotify in a box effectively,  so thanks for the recommendation Millemissen. Don't think my finances will stretch to a playmaker, and never really liked the look of it anyway.
Thanks again,
Graeme.
Millemissen
Flensborg, Denmark
Posts 14,680
Glad to have helped!
The Playmaker is a much more versatile device - and with a higher SQ.
Using it to feed a BeoMaster you can hide it away - if you don't like the looks of it.
But - really - if you just need a device for Spotify (Connect) the Gramofon is absolutely fine.
And it is cheaper - of course.
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Fri, Jan 16 2015 10:51 AM
The airport express isn't very good sound quality wise.
If you want to keep the B&O product line the playmaker would be a great option.
Too long to list....
Page 1 of 1 (11 items) | RSS
DigiCert Secured Site Seal
