Hello,
Decided to get to the bottom of a problem with an old 'E-Bay' purchase - perhaps someone can assist.
MCP 5500 seems to work fine - can audibly hear the Mute Relay cycle.
No audio output from RH speaker (either 1 or 2) when using Tape2/Aux RCA Jacks - However, both L & R channels work with Radio - no other hook-ups available for testing.
Using headphone jack yields the same results - radio 'yes' - TP2 - NO
So, it would seem the problem is with the RH Tape2 Input (or somewhere after that).
Any suggestions would be welcome.
Thanks,
Rob
Welcome to Beoworld !
Pull the mains plug and take off the bottom plate.Resolder the joints at the RCA sockets and the long row of joints where the vertical (DIN-) connector bay board meetsthe preamp board (that's right in front of the RCA sockets).If you use a type of solder with a small amount of silver in it, the joints will not crack easily again.Cracked solder joints in this area is a known problem in this model.
Thanks for the Welcome, Martin!
Will check it out, and get back to everyone on how it worked.
Best regards,
