TWG: Beojeff, I need your help, too. I can controll the HUE lights from the Beo 4 and 5 but they are not related to any room. If I choose "any room" in MLGW setup, every command works fine. But when I specify a room (e.g. "bedroom") there's no reaction to light commands.I want to use the red and green buttons of the Beo 4 in any room for simple light on/off commands. So the use of the green button of Beo 4 in the bedroom should ONLY switch on the lights in the bedroom while the use of the green button of the Beo 4 in the livingroom should only activate the lights in the livingroom.How can I achieve that?
TWG-
I've only used "any room" for my commands. So I'm not sure why your commands aren't working. It seems that they should!
You might want to check all of you macros to make sure you haven't used those triggers in other macros -- which could cause a conflict. I've accidentally don't and found it to be the reason some macros wouldn't work.
