HDMI - SDI aerial converter question
MJBeo
Netherlands
Posts 270
MJBeo Posted: Wed, Aug 19 2015 10:33 AM
Hi, I have a BV7-32 MKIII without HDMI connections, and I would like to connect HD (ready) sources. I have one connected to the DVI, and one to the component connection. I would like to connect a third HDMI source, and I found this box to convert HMDI to SDI signal. I know this is a ridiculously expensive box, but just as a thought, would this add an extra 1080i source to the TV?
And if so, would it be possible to send this source over ML and get HD reception in link room Beovisions? Or would it still be only Video quality?
I am probably not going down this path, since buying a HDMI switch is cheaper, but if anyone has tried this I would like to hear their experience.
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Aug 19 2015 10:46 AM
SDI is a baseband serial digital connection and has nothing to do with RF (aerial) distribution, so this box doesn't apply to your problem at all.
--mika
MJBeo
Netherlands
Posts 270
MJBeo replied on Wed, Aug 19 2015 11:43 AM
tournedos:
Aha, I thought I overlooked something... I have no knowledge in this domain. Is it even possible to use the RF aerial input for anything else than cable TV and satellite?
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Aug 19 2015 12:50 PM
MJBeo:
...and terrestrial TV. Locally, you can only use it to distribute SD analogue video, because for digital transmissions the required "modulator" (of sorts) is far too complex and expensive to include in any domestic AV kit. Local distribution of HD video is much easier to do over IP, but that's obviously not supported directly by older TVs.
--mika
BeoMotion
Posts 384
BeoMotion replied on Wed, Aug 19 2015 5:51 PM
MJBeo:
If you update your TV to the latest SW (30.08a) you can connect an HDMI switch. Then you could connect up to 4 HDMI sources depending on the model.
B&O recommends using a GEFEN TV switch which can be controlled by puc. It is also possible using a cheap generic one with automatic source switching.
If your TV is not running on one of the more recent SW versions you can also use a HDMI switch but cannot assign more than one source to the DVI input. This might be a problem when you want to use multiple HDMI sources with different PUCs.
Griebel
Posts 416
Griebel replied on Thu, Aug 20 2015 8:28 AM
I'm using the Gefen HDMI switch with my 7-32 and it works perfectly. On the bad side, the Gefen is not cheap.
MJBeo
Netherlands
Posts 270
MJBeo replied on Thu, Aug 20 2015 8:45 AM
Griebel:
Thanks I will look at it. Are you able to switch on the sources using DTV and V.MEM buttons? And you probably also need one or more dacs or extractors for the sound?
BeoMotion
Posts 384
BeoMotion replied on Thu, Aug 20 2015 9:21 AM
MJBeo:
Yes, this will work if everything is set up correctly.
MJBeo:
Most devices have a separate digital audio out. You can connect this directly to the BV7. You only need external DAC(s) if you want to send the sound to ML.
Page 1 of 1 (8 items) | RSS
