Beosystem 3 MK1 Supported video output.
bophile
Posts 14
bophile Posted: Thu, Sep 10 2015 3:17 PM
Hello Friends,
I'm in the process to upgraded to Full HD  the panel (an Old  HD ready 1366x720p 42" Panasonic Plasma) hooked to  a Bosystem3 MARK 1 (DVI Display out) .
Reading Beosystem3 threads here and in the archived forums and also asking around some dealers , I'm still confused if the Beosystem3 is able to output Full HD (1980x1024p) signal. It's running 4.17a SW version (I know it's old) , but I have understood that starting from version SW version 3 the full HD was supported.
Any clues ?
Also if somebody has the BS3 system manual (SW version 3 or superior, you can read the software version on the front page of the manual) could you share what are you reading at the video output section around page 6.5 ?
Thanks a lot.
frog
Camberley UK
Posts 624
frog replied on Thu, Sep 10 2015 4:11 PM
I'm nowhere near the screen right now but if you go into the engineering section of the menu (iirc menu, red, go) go to the monitor section then choose non-B&O display and set the parameters to 1080i.
not sure that this is exactly correct, but should be close - was some years ago I did it!
regards
frog
bophile
Posts 14
bophile replied on Thu, Sep 10 2015 4:36 PM
Thanks ! will try that out.
Page 1 of 1 (3 items) | RSS
