Hi people, i have recently purchased a Beosound moment and Beosound 18 speakers as well as Beosound 19 subwoofer. (I have been a B and O user since 1996) I have been running this new system with a mac book pro and Twonky server (what ever that is) anyway i need to buy a NAS server though.
As always B and O is not much help when it comes to "user friendly" software or non b and o solutions. What would you recommend, im not really interested in low price i just want to buy the best server to stream music.
Thanks for the help
Hi driceman, and welcome to the forum. There are several threads about the Moment player on the forum, so use the search function to find them.
I have a dedicated only for music Mac mini I7 with Twonky server 8.0.3, exclusively running 24/7 for the Moment and this combination serves me well.
I use this server strictly because of stability. In the case you find it to costly then I would recommend a QNAP 2-bay NAS as cheaper. QNAP has Twonky also as a app to install. To date there is no other server program that is stabile and usable with the Moment, only Twonky server works with the Moment well.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Thank you for your time and advice Chris
and if you want a NAS with style and great build quality you should have a look at the new "DELA" made by Buffalo:
http://www.sempre-audio.at/Dela_N1A_und_Dela_N1Z_-_Buffalo_Inc-_praesentiert_NAS-Loesungen_fuer_High-end_HiFi.id.3849.htm
