Beolab 3000 blows fuses
This post has 4 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Sat, Nov 14 2015 3:17 PM
Hi
just got hold of a cheap set of Beolab 3000 because one unit is working.. The display and data readout works perfect, but there is no sound..
first checked fuse 1 and 2, and they were both blown.. Changed them and the speaker made humming noise for 3 seconds, and then the fuses blew again..
anyone had this issue on similar beolabs ?
The speakers both work fine as passive units.,
/weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sun, Nov 22 2015 9:58 AM
Sadly it turns out to be the amplifier IC STK4042V that is done for.. They are not available anymore, so I will be looking out for some used ones in the future. I am also concidering to buy a used 4042II IC's. They are the same becides the V's having less distortion..
/weebyx
phil
Posts 40
phil replied on Sun, Nov 22 2015 11:37 PM
I have these speakers, not had this issue, but have had one pair go faulty, i narrowed the fault down to a plug in circuit board that plugs into the mother board, my fault was no display and no sound, just the red indicator light.
Fitting a known working board cured the fault, sadly it seems most if not all parts for these speaker amps are no longer available as i've tried before.
hemenex
Posts 569
hemenex replied on Tue, Nov 24 2015 4:33 PM
Eventually this might help:
LINK
The XI looks like a version with even lower THD (0.008%).
It's the one I have ordered some years ago as a probable replacement. Never tried it yet.
  hx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Nov 24 2015 9:11 PM
hemenex:
LINK
  hx
That looks great (if they works), but I actually managed to get a hold of a V version from an old damaged amplifer, now mine works again, but could be great to figure out if yours would work :) ?
What could be the reason for this IC dying ?
/Weebyx
Page 1 of 1 (5 items) | RSS
